查看: 57|回复: 1
help. being held hostage by this app
 楼主| 发表于 2022-1-1 04:51:09 来自手机 | 显示全部楼层 |阅读模式
{"text":"I used trucker path for navigation and now it won't let me get rid of the business I went to. why? and how can I fix it? thanks","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2022-1-12 10:28:16 来自手机 | 显示全部楼层
{"replyTo":"","text":"I've had the same problem and found a work around that has helped me. So, start a new route to wherever you're going next, like a truck stop or whatever. When you finally get there, it should ask you if you've arrived at your destination and you can respond yes. That old route you just can't seem to get rid of should be gone now. At least that has worked for me. It seems that even if you 'quit' a route, it doesn't necessarily remove the route until you 'complete' the route and indicate as such. Since it only seems to hold one route at a time. Route yourself to some other place, such as the truck stop you're about to stop at anyway.\nHope that helps!!!","replyToPid":0}
GMT+8, 2026-4-16 05:14 , Processed in 0.087575 second(s), 24 queries .
