查看: 666|回复: 8
Antigel for reefer
 楼主| 发表于 2021-12-30 16:52:07 来自手机 | 显示全部楼层 |阅读模式
{"text":"Hi! Do I have to use Antigel for my reefer too? If yes how much should I add? ","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2021-12-31 01:44:28 来自手机 | 显示全部楼层
{"replyTo":"","text":"can you not read? instructions are on the bottle.","replyToPid":0}
回复 支持 4 反对 1
发表于 2021-12-30 21:29:57 来自手机 | 显示全部楼层
{"replyTo":"","text":"yes","replyToPid":0}
回复 支持 1 反对 3
发表于 2021-12-31 01:08:37 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"You don't HAVE to, but I recommend it if you're gonna be in really cold weather. I will run my reefer on CONTINUOUS if temps will be 10° or less. Uses a little more fuel, but cheaper than a freeze up! You really can't add too much anti-gel. I operate under the idea that, when very cold,  more is better! I will add at least 1/4ish bottle of Howes to the reefer tank & split a full 64 oz bottle  between my 135 gal truck tanks. DO NOT buy anti-gel @ the truckstop!!! Walmart has for $9-10/bottle. If you live in the Midwest, Menards is the cheapest place to buy it. I buy 2-3 6 bottle cases every year @ $7/bottle when on sale."}
发表于 2021-12-30 16:58:11 来自手机 | 显示全部楼层
{"replyTo":"","text":"I pour one fourth of the bottle in my reefer tank, then split the rest between the tractor tanks.","replyToPid":0}
发表于 2022-1-6 22:51:35 来自手机 | 显示全部楼层
{"replyTo":"","text":"You add the the anti-gel in the engine oil so the engine don’t freeze up. Put some in the coolant also. If you pour a large coffee cup of salt in the fuel tank in your reefer that will keep the ice water out. ","replyToPid":0}
 楼主| 发表于 2022-1-13 00:59:38 来自手机 | 显示全部楼层
1037330 发表于 2022-01-06 14:51:35 You add the the anti-gel in the engine oil so the engine don’t freeze up. Put some in the coolant also. If you pour a large coffee cup of salt in the fuel tank in your reefer that will keep the ice water out.
","text":"Are you serious? 🙄","replyToPid":456712}
发表于 2022-1-1 15:43:39 来自手机 | 显示全部楼层
{"replyTo":"","text":"I wouldn't. if you have a frozen load and leave it on continuous","replyToPid":0}
发表于 2022-1-15 00:41:40 来自手机 | 显示全部楼层
{"replyToPid":457384,"replyTo":"","text":"Of course I’m serious all super truckers do that shït. Get with the program son "}
GMT+8, 2026-4-17 15:04 , Processed in 0.113316 second(s), 24 queries .
