查看: 158|回复: 3
Need Help For Snowy Grade
 楼主| 发表于 2021-12-29 10:40:22 来自手机 | 显示全部楼层 |阅读模式
{"text":"I’m in the recovery fleet of my company, and currently sleeping on I-80 in Wyoming. Heading into Laramie, there is a 5% grade in the mountains for 5 miles. The issue is, this truck I’ve recovered has no working cruise control, cant switch to manual, and the gears auto shift upward as it gains speed. My company won’t route me back east to get this fixed. They just repeated “drive for conditions; wait till it’s safe”. If I have to wait till it’s safe I’d be waiting till spring! I’m not sure what to do as cruise control and jake braking causes jackknifes on snowy roads. What should I do about this? Would first or second gear jake brake help? It’s either a 2018-19 freightliner. And to make things worse, this truck has been in an accident before!","videos":"[]","link":"{}","pics":"[{\"description\":\"\",\"height\":1512.0,\"name\":\"\",\"url\":\"\",\"width\":2016.0}]","canComment":true,"externalShare":false}
发表于 2022-1-7 09:05:22 来自手机 | 显示全部楼层
{"replyTo":"","text":"I slow it down to the speed I want to go first using the brakes and then turn the engine brake on the lowest setting.  In my truck it won’t upshift if the engine brake is on and you aren’t touching the accelerator. ","replyToPid":0}
发表于 2022-1-7 09:00:52 来自手机 | 显示全部楼层
{"replyTo":"","text":"Does the engine brake work?","replyToPid":0}
发表于 2022-1-7 09:08:43 来自手机 | 显示全部楼层
{"replyTo":"","text":"If you can go up a slick hill without the drives spinning then you can go down that hill without the drives sliding when you turn on the Jake brake.  \n\nPut your flashers on and go 25 mph if you need to.  ","replyToPid":0}
GMT+8, 2026-4-17 18:25 , Processed in 0.085504 second(s), 24 queries .
