查看: 95|回复: 4
Drive
 楼主| 发表于 2021-12-27 13:15:03 来自手机 | 显示全部楼层 |阅读模式
{"text":"Good morning 😃,does anyone know how to program in truck restrictions inside city limits for trucker path?","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2021-12-27 20:25:28 来自手机 | 显示全部楼层
{"replyTo":"","text":"Buy Atlas! problem solved","replyToPid":0}
 楼主| 发表于 2021-12-28 14:14:07 来自手机 | 显示全部楼层
1295275 发表于 2021-12-27 12:25:28 Buy Atlas! problem solved
","text":"Alright thanks 😊 ","replyToPid":455952}
发表于 2021-12-28 11:58:43 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"When setting course, before you tap navigation, theres a edit and settings Cog In the top right corner, tap that and Towards the bottom you should see truck settings, you can enter weight, height, and size. Drive safe!"}
 楼主| 发表于 2021-12-28 14:14:58 来自手机 | 显示全部楼层
1369385 发表于 2021-12-28 03:58:43 When setting course, before you tap navigation, theres a edit and settings Cog In the top right corner, tap that and Towards the bottom you should see truck settings, you can enter weight, height, and size. Drive safe!
","text":"Okay, I think this can help thank you ☺️ ","replyToPid":455999}
GMT+8, 2026-2-7 11:03 , Processed in 0.085413 second(s), 24 queries .
