查看: 336|回复: 12
Can you drive with one flat tire on a trailer?
 楼主| 发表于 2021-12-19 21:55:53 来自手机 | 显示全部楼层 |阅读模式
{"text":"I catch flat tires on trailers I have to pick up all the time! Can you get away with driving a trailer with one flat tire to your destination and then call maintenance after? \n\nIt’s not shredded or blown out! When you hit the tire you can tell by the sound it’s flat! About how many miles can you go?","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2021-12-20 04:13:01 来自手机 | 显示全部楼层
{"replyTo":"","text":"I always immediately get it fixed, appointments can be changed, 1 shredded tire can possibly cause a fatality and also damage other vehicles in the travel lanes","replyToPid":0}
回复 支持 5 反对 2
发表于 2021-12-19 23:31:43 来自手机 | 显示全部楼层
{"replyTo":"","text":"You're the driver of your own rig. You can do anything you want. But there may be consequences if you get caught. I'm sure everyone here has driven a trailer with a flat. Just depends how far you wanna go.","replyToPid":0}
回复 支持 6 反对 0
发表于 2021-12-20 02:21:47 来自手机 | 显示全部楼层
{"replyTo":"","text":"Have a longer air hose with you at all times to get you out of such jams till it can be fixed  at a time where’s it more of ur own convenience. \nYou can make up fittings so you just quick couple into ur air Supply tanks ","replyToPid":0}
禁止发言
发表于 2021-12-19 22:07:32 来自手机 | 显示全部楼层
禁止发言
发表于 2021-12-19 23:14:45 来自手机 | 显示全部楼层
发表于 2021-12-21 11:53:00 来自手机 | 显示全部楼层
{"replyTo":"","text":"bacooćk","replyToPid":455308}
发表于 2021-12-21 11:29:08 来自手机 | 显示全部楼层
{"replyTo":"","text":"pp does it","replyToPid":0}
发表于 2021-12-19 22:45:50 来自手机 | 显示全部楼层
{"replyTo":"","text":"You can’t drive with a flat tire regardless of the weight. You can remove the flat tire depending on your weight, but a flat tire will always be a violation.","replyToPid":0}
1万
发表于 2021-12-19 22:32:07 来自手机 | 显示全部楼层
{"replyTo":"","text":"good morning old marine...\nI tried answering but it wouldn't let me, it thought I was saying something bad...\nb  l. o. w. a tire. ???","replyToPid":455250}
发表于 2021-12-21 10:09:05 来自手机 | 显示全部楼层
{"replyTo":"","text":"Absolutely not","replyToPid":0}
GMT+8, 2026-2-7 11:03 , Processed in 0.111771 second(s), 24 queries .
