查看: 283|回复: 2
bad review
 楼主| 发表于 2021-12-6 16:16:02 来自手机 | 显示全部楼层 |阅读模式
{"text":"Usually I don't leave bad reviews but this time it went too far. R2 logistics is definitely the worst brokerage I've ever worked with so far. They are liars. They will do anything so you take the load but when it comes to deliver the load that's when you have a problem. Good luck if you ever work with them","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2021-12-6 17:06:12 来自手机 | 显示全部楼层
{"replyTo":"","text":"very little information,  bad English, maybe a communication problem. all brokerages run into trouble sometimes.","replyToPid":0}
回复 支持 0 反对 5
发表于 2021-12-6 22:38:00 来自手机 | 显示全部楼层
1382419 发表于 2021-12-06 09:06:12 very little information,  bad English, maybe a communication problem. all brokerages run into trouble sometimes.
","text":"You are one to give advice! You can't survive in trucking world .Thus you always 😭😭😭😭😭 about bring broke","replyToPid":454285}
GMT+8, 2026-3-21 11:19 , Processed in 0.085392 second(s), 24 queries .
