查看: 133|回复: 5
Big company trailer “rentals”
 楼主| 发表于 2021-11-30 07:52:39 来自手机 | 显示全部楼层 |阅读模式
{"text":"I wish there was a way to recover from other drivers leaving me a garbage drop trailer. This trailer is a piece of work. It was missing the valve pull for the tandems so I needed a repair shop for that. Then the reefer had lost its programming so it screamed at me for 30+ hours! In the truck and my phone. If another driver makes me fix all that and I sit at the receiver all day long I should be compensated for that. I was late to my appointment and worked in at the end of the day. So I sat unpaid all day long because someone else wouldn’t fix it. Maybe they need a personal charge or something. Or something. I don’t know. ","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2021-11-30 08:45:23 来自手机 | 显示全部楼层
1339891 发表于 2021-11-30 00:05:19 Do you understand trucking isn't a perfect world? Things always goes wrong.  You should expect the unexpected!!!
","text":"if other drivers would report all the stuff that needs repair would be the Right thing to do but this business is full of s hit heads who get their jollies out of scre wing other drivers.","replyToPid":453853}
回复 支持 6 反对 0
发表于 2021-11-30 08:05:19 来自手机 | 显示全部楼层
{"replyTo":"","text":"Do you understand trucking isn't a perfect world? Things always goes wrong.  You should expect the unexpected!!!","replyToPid":0}
发表于 2021-11-30 21:31:22 来自手机 | 显示全部楼层
{"replyTo":"","text":"Change to flatbeding you don't have that problem it's harder work but you don't have the BS","replyToPid":0}
发表于 2021-11-30 08:25:26 来自手机 | 显示全部楼层
{"replyTo":"","text":"Come switch to dry van, baby.  Less bullshît like that to worry about ","replyToPid":0}
发表于 2021-11-30 17:42:11 来自手机 | 显示全部楼层
{"replyTo":"","text":"I agree . you should be compensated .","replyToPid":0}
GMT+8, 2026-2-7 23:28 , Processed in 0.341927 second(s), 24 queries .
