查看: 185|回复: 13
Any of you Leased-On O/O ever turn down a load
 楼主| 发表于 2021-11-30 04:00:37 来自手机 | 显示全部楼层 |阅读模式
{"text":"I don’t like when they try to send me to Memphis. ","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
禁止发言
发表于 2021-11-30 04:06:32 来自手机 | 显示全部楼层
禁止发言
发表于 2021-11-30 04:10:32 来自手机 | 显示全部楼层
发表于 2021-11-30 07:36:08 来自手机 | 显示全部楼层
{"replyTo":"","text":"Easy answer don't go. problem solved","replyToPid":0}
发表于 2021-11-30 16:17:07 来自手机 | 显示全部楼层
{"replyTo":"","text":"If own the truck move it to a carrier that lets you use a load board  to pick your own loads. If you lease a truck your stuck like chuck and I wouldn’t complain if like to make money ","replyToPid":0}
禁止发言
发表于 2021-11-30 04:07:49 来自手机 | 显示全部楼层
 楼主| 发表于 2021-11-30 07:49:46 来自手机 | 显示全部楼层
{"replyToPid":453845,"replyTo":"
1295275 发表于 2021-11-29 23:36:08 Easy answer don't go. problem solved
","text":"real man of genius you are "}
 楼主| 发表于 2021-11-30 19:14:40 来自手机 | 显示全部楼层
81153 发表于 2021-11-30 08:17:07 If own the truck move it to a carrier that lets you use a load board  to pick your own loads. If you lease a truck your stuck like chuck and I wouldn’t complain if like to make money
","text":"I own the truck ","replyToPid":453888}
发表于 2021-12-1 21:56:17 来自手机 | 显示全部楼层
{"replyTo":"","text":"If you own your own truck you have a right, as I do, you have a right to turn down any loads. If they don't like it look for another company","replyToPid":0}
发表于 2021-12-2 08:22:27 来自手机 | 显示全部楼层
{"replyTo":"","text":"Too much black crime in Memphis dawg just say no ","replyToPid":0}
GMT+8, 2026-2-7 22:40 , Processed in 0.059046 second(s), 24 queries .
