查看: 293|回复: 9
Do you need to turn on ELD if you only running bobtail
 楼主| 发表于 2021-11-28 14:32:16 来自手机 | 显示全部楼层 |阅读模式
发表于 2021-11-28 23:04:38 来自手机 | 显示全部楼层
{"replyTo":"","text":"Are you pushing truck or driving it ","replyToPid":0}
回复 支持 8 反对 0
发表于 2021-11-28 18:08:11 来自手机 | 显示全部楼层
{"replyTo":"","text":"Here’s your sign 🪧 ","replyToPid":0}
回复 支持 7 反对 0
发表于 2021-11-29 13:14:51 来自手机 | 显示全部楼层
{"replyTo":"","text":"First time caller, long time listener............Do I need to run a log book even if I'm not hauling logs?? I need an answer quick......scales open and I'm sitting on the ramp......","replyToPid":0}
回复 支持 4 反对 1
发表于 2021-11-28 21:59:11 来自手机 | 显示全部楼层
936953 发表于 2021-11-28 10:08:11 Here’s your sign 🪧
","text":"🤣👍","replyToPid":453667}
发表于 2021-11-29 11:00:29 来自手机 | 显示全部楼层
{"replyTo":"","text":"If your at “work” you need to be on the clock… 🤷‍♂️ but yes you can cheat, it’s fun to cheat, till you get caught…. Or get in a wreck and someone gets hurt bad or worse killed… then your breaking federal laws and they like to put people in jail for that! 🤔","replyToPid":0}
发表于 2021-11-29 11:08:25 来自手机 | 显示全部楼层
{"replyTo":"","text":"Yes it needs to be on yes you can used personal conveyance as long as you are not advancing a load ","replyToPid":0}
发表于 2021-11-29 01:15:11 来自手机 | 显示全部楼层
{"replyTo":"","text":"Are you a truck driver or a city slicker","replyToPid":0}
发表于 2021-11-30 04:50:03 来自手机 | 显示全部楼层
{"replyTo":"","text":"Unplug the Omni tracs and go bobtail around and pick up your side piece and tell her forget_about_your_boyfriend & meet-me-at-the-hotel 📲🏪","replyToPid":0}
发表于 2021-11-30 00:25:06 来自手机 | 显示全部楼层
{"replyTo":"","text":"I'm an o/o and if I'm bobtail and not working I don't worry about eld.......","replyToPid":0}
GMT+8, 2026-4-17 13:33 , Processed in 0.124526 second(s), 24 queries .
