查看: 73|回复: 2
DPF filter?
 楼主| 发表于 2019-1-28 18:29:54 来自手机 | 显示全部楼层 |阅读模式
{"text":"How often or when do you replace DPF filter? I am right at 220,000 miles but I lost a crank and was going through a gallon of oil between last few oil changes. It is on a 2012 Cascadia with a Cummins.","pics":"[]","canComment":true}
发表于 2019-3-2 12:17:53 来自手机 | 显示全部楼层
{"replyTo":"","text":"I got 400,000 out of my first ones got a Detroit dd15 tho","replyToPid":0}
发表于 2019-4-10 07:25:36 来自手机 | 显示全部楼层
{"replyTo":"","text":"Check engine will come on,and when you go to the dealer they will tell you it’s time to change the DPF filter, I changed mine around 320000 mi","replyToPid":0}
GMT+8, 2026-4-17 08:05 , Processed in 0.075743 second(s), 23 queries .
