查看: 278|回复: 12
Question for some other owner operators out there
 楼主| 发表于 2021-11-21 12:15:32 来自手机 | 显示全部楼层 |阅读模式
{"text":"\nThinking about diversifying my excavating business, and buying another old dinosaur of a truck for otr. are there companies out there that will lease on a truck from the 80s? What are you guys’s thoughts on this","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2021-11-21 13:39:20 来自手机 | 显示全部楼层
{"replyTo":"","text":"Why not just get your own authority","replyToPid":0}
发表于 2021-11-22 20:44:02 来自手机 | 显示全部楼层
1373340 发表于 2021-11-22 09:56:59 There are still some Never E-log drivers out there huh.
","text":"There are still some loopholes that are keeping paper perfectly legal. ","replyToPid":452800}
发表于 2021-11-22 21:23:21 来自手机 | 显示全部楼层
","text":"Yea n im one of em 2022 pete 389 got Signature 600 stickers on my motor lol","replyToPid":452800}
发表于 2021-11-22 17:56:59 来自手机 | 显示全部楼层
{"replyTo":"","text":"There are still some Never E-log drivers out there huh. ","replyToPid":0}
回复 支持 0 反对 3
禁止发言
发表于 2021-11-21 20:10:35 来自手机 | 显示全部楼层
 楼主| 发表于 2021-11-22 09:16:49 来自手机 | 显示全部楼层
147103 发表于 2021-11-21 12:10:35 I was at a delivery.  Another driver pulled in driving a 1953 mack. I was talking to him about the truck. I noticed it was leased to a company in Montana.  I asked if he had any issues getting truck leased on. He said No. it passed a Dot inspection.  He also was running E-log. Company policy.
","text":"That guy is probably alright ","replyToPid":452745}
 楼主| 发表于 2021-11-22 00:32:38 来自手机 | 显示全部楼层
","text":"I’m not going to run the e log ","replyToPid":452745}
发表于 2021-11-22 01:14:09 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"Where are you from 4.0?\nWith an excavation business, you could put a commodities dump or a small belt trailer (55-60 cu. Yd.) and use it for your business any time you aren’t under someone else’s load. I’d think it’d be to your advantage to get your own numbers. \n     I run over a hundred thousand miles a year under a 40’ dump. "}
 楼主| 发表于 2021-11-22 01:29:01 来自手机 | 显示全部楼层
{"replyTo":"","text":"Upper Michigan ","replyToPid":0}
GMT+8, 2026-2-8 04:02 , Processed in 0.064302 second(s), 24 queries .
