查看: 69|回复: 2
With every update we lose more functionality
 楼主| 发表于 2021-11-17 20:29:00 来自手机 | 显示全部楼层 |阅读模式
{"text":"1. Truckers Path has removed the blue routing button. It’s no longer front and center. Instead it randomly appears and disappears with no known pattern. Now if you want to change your routing you have to clear your trip plan so that you can make changes.\n\n2. I woke up this morning to discover that Trucker Path has removed the places button and that there is now no way to deselect icons off the map. I like a clean map, only showing icons I want. I was using the low clearance icons last night and now I can’t remove them.\n\n3. I like being able to swipe up to do searches for places but when I’m done with it, it needs to go away. Not taking up real estate on my map. Again I like a clean map.\n\nTrucker Path if you want to streamline the map that’s fine. Move the routing and the ability to deselect icons to the swipe up section. Just don’t remove them.\n\nP.S. why is there not a section on the forum for talking about the app? You would think that you would want to know what we think.","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2021-11-18 05:01:08 来自手机 | 显示全部楼层
{"replyTo":"","text":"Quit making “improvements.” Rather, spend more time on keeping the app from shutting down. Excellent tool as is and when not shutting down.","replyToPid":0}
发表于 2021-11-19 23:34:30 来自手机 | 显示全部楼层
{"replyTo":"","text":"There is a place on the app to talk directly to technical support. I have used it several times. With that being said, I pay for premium. I don’t know if that makes a difference. ","replyToPid":0}
GMT+8, 2026-2-8 08:56 , Processed in 0.067943 second(s), 23 queries .
