查看: 204|回复: 10
I have a sinus infection. Any home recipes to help speed up recovery?
 楼主| 发表于 2021-11-4 21:05:53 来自手机 | 显示全部楼层 |阅读模式
{"text":"Taking over the counter medicine. I think I’m at the point where I’m recovering a bit. Any remedies for the road? ","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2021-11-6 20:07:45 来自手机 | 显示全部楼层
{"replyTo":"","text":"Crystal light concentrated drink mix.  30 ml bottles.  Main ingredient is vitamin C.  About 8 ml a day max.  You might experience a bit of upset tummy but increased ph levels will help fight the symptoms of your immune response.   ","replyToPid":450916}
发表于 2021-11-5 19:20:20 来自手机 | 显示全部楼层
546460 发表于 2021-11-04 21:06:40 No fever did a rapid covid test came up negative.
","text":"Thanks be to God","replyToPid":450746}
发表于 2021-11-6 06:01:53 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"I've got a whole story book on remedies that's been passed down thru my family over 200 years, I could help you but I'd have to charge you $100 per cure and $250 for the convenience fee\nBE WELL"}
发表于 2021-11-5 01:04:06 来自手机 | 显示全部楼层
{"replyTo":"","text":"Just take it easy and eat right. If you have a fever it may be something else? If so, go to urgent care.  ","replyToPid":0}
发表于 2021-11-5 03:19:37 来自手机 | 显示全部楼层
{"replyTo":"","text":"Take honey from your local region","replyToPid":0}
 楼主| 发表于 2021-11-5 05:06:40 来自手机 | 显示全部楼层
655805 发表于 2021-11-04 17:04:06 Just take it easy and eat right. If you have a fever it may be something else? If so, go to urgent care.
","text":"No fever did a rapid covid test came up negative. ","replyToPid":450725}
发表于 2021-11-6 06:27:02 来自手机 | 显示全部楼层
{"replyTo":"","text":"Coke ","replyToPid":0}
 楼主| 发表于 2021-11-6 09:15:33 来自手机 | 显示全部楼层
{"replyTo":"","text":"This is the way lol","replyToPid":450905}
发表于 2021-11-7 08:28:35 来自手机 | 显示全部楼层
{"replyTo":"","text":"Add 1 cup (240 mL) distilled water to a clean container. If you use tap water, boil it first to sterilize it, and then let it cool until it is lukewarm.\nAdd 0.5 tsp (2.5 g) salt to the water.\nAdd 0.5 tsp (2.5 g) baking soda.\n\nPour in one nostril out the other \n","replyToPid":0}
GMT+8, 2026-3-22 15:34 , Processed in 0.084589 second(s), 24 queries .
