查看: 200|回复: 12
2022 Cascadia DD15?
 楼主| 发表于 2021-11-3 10:51:17 来自手机 | 显示全部楼层 |阅读模式
{"text":"I started driving this truck brand new back In July and recently 3 Weeks ago It started running like it lost power. I have no check engine lights no DEF/regen lights but it’s running like something is clogged and it makes an annoying gargling/grinding noise when I have my foot on accelerator or when cruise control is on. Had my company hook it up to computer but no codes nothing. Any suggestions? I’ve been driving these Cascadias since 2017 and never experienced this","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2021-11-3 11:06:26 来自手机 | 显示全部楼层
{"replyTo":"","text":"check the intake air filter, if not upstream, check down stream and replace the DEF filter canisters.","replyToPid":0}
回复 支持 1 反对 4
发表于 2021-11-3 11:07:29 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"replace all fuel filters and water separator filter.\n\nobviously do the least expensive stuff first. fuel filter, air filter, def filter."}
回复 支持 1 反对 3
发表于 2021-11-5 23:17:09 来自手机 | 显示全部楼层
1360751 发表于 2021-11-03 03:07:29 replace all fuel filters and water separator filter.\n\nobviously do the least expensive stuff first. fuel filter, air filter, def filter.
","text":"Accume tell everyone.  when you played the reviewer.  you was on here crying because you didn't change oil in truck but every 3 months and it blowed up. So I doubt anyone needs your Swift logic","replyToPid":450588}
禁止发言
发表于 2021-11-3 20:41:10 来自手机 | 显示全部楼层
 楼主| 发表于 2021-11-3 11:41:55 来自手机 | 显示全部楼层
766797 发表于 2021-11-03 03:27:15 check all hose connections and clamps to from turbo to air cooling and from air cooling to the engine not sure if you have sensors but check if sensor on exhaust manifold or behind turbo on elbow ... if yes check on gauges for temperature if on manifold pyrometer should be between 1050 to 1300 if on exhaust should be 609 to 850 also if gauge set for manifold PSI  SHOULD BE ON STRAIGHT WAY  750 to 900 range if not you have \n1. air restrictions \n2. fuell restrictions \n3. air cooler leak\n4. turbo problem \n5. injectors issue \n......\n...\n.
","text":"Thank you Pete on Pete","replyToPid":450595}
 楼主| 发表于 2021-11-3 11:23:20 来自手机 | 显示全部楼层
1360751 发表于 2021-11-03 03:06:26 check the intake air filter, if not upstream, check down stream and replace the DEF filter canisters.
","text":"Appreciate you ","replyToPid":450587}
 楼主| 发表于 2021-11-3 11:24:14 来自手机 | 显示全部楼层
","text":"Thank you much","replyToPid":450588}
 楼主| 发表于 2021-11-5 07:53:35 来自手机 | 显示全部楼层
{"replyTo":"","text":"Well solved the puzzle today, the turbo clamps were loose. ","replyToPid":0}
 楼主| 发表于 2021-11-5 08:43:00 来自手机 | 显示全部楼层
147103 发表于 2021-11-03 12:41:10 I had similar issue my truck. I had to do forced regen. I had no codes either.
","text":"So your issue went away after you performed parked regen?","replyToPid":450606}
禁止发言
发表于 2021-11-5 21:46:18 来自手机 | 显示全部楼层
GMT+8, 2026-2-8 03:56 , Processed in 0.069040 second(s), 24 queries .
