查看: 198|回复: 9
How fast can you drive with chains or cables?
 楼主| 发表于 2021-10-29 18:05:19 来自手机 | 显示全部楼层 |阅读模式
发表于 2021-10-29 22:10:18 来自手机 | 显示全部楼层
{"replyTo":"","text":"Hammer down until you see asphalt flying then back off 5, Homer","replyToPid":0}
发表于 2021-10-29 20:13:53 来自手机 | 显示全部楼层
766797 发表于 2021-10-29 11:50:54 I do not drive if they are in need but to save the equipment I do not recommend more than 20mph
","text":"Good advice, Pete ","replyToPid":450205}
发表于 2021-10-31 22:47:40 来自手机 | 显示全部楼层
{"replyTo":"","text":"95","replyToPid":0}
发表于 2021-10-31 18:37:51 来自手机 | 显示全部楼层
{"replyTo":"","text":"0 mph is my best guess. Might as well park it. I had to use them 1 time on a side highway because the ts was past the indicator sign. Boohoo. Broke my chains at 20 mph and it took out my bumper. Had to get new chains and bumper. Never again will I do chain driving. Too expensive. Just park it. And no one ever taught me so I was left crying on the side of the road in an icy muddy ditch trying to figure it out. No fun. ","replyToPid":0}
 楼主| 发表于 2021-10-30 09:35:46 来自手机 | 显示全部楼层
{"replyTo":"","text":"Thanks everyone! I haven’t used chains yet and just wondering in case I had to use them! I was watching the video “riding shotgun” on YouTube! This guy is unbelievably good at driving in treacherous winter conditions! In one of the videos he had chains on in the vail pass at night and it looked like he was driving faster than 35!","replyToPid":0}
发表于 2021-10-30 21:51:55 来自手机 | 显示全部楼层
{"replyTo":"","text":"Yes cables are junk. They are easier to put on, but don't offer the traction of chains and will come apart and trash an airbag. Chains installed correctly(straight and tight) will do fine to 30-35 mph","replyToPid":0}
发表于 2021-10-30 02:59:04 来自手机 | 显示全部楼层
{"replyTo":"","text":"the faster you go the more you tear your stuff up","replyToPid":0}
发表于 2021-10-30 06:32:40 来自手机 | 显示全部楼层
{"replyTo":"","text":"I would never use cables, ever.  Many areas they are illegal  As for chains 50kmph or 35mph for good heavy chains like Trygg (44kg / 100lb per triple).  Make sure they are on tight or it doesn't matter what you use you will shred them, tires and equipment.  If unsure, park it call it a day.  No freight or carrier is worth your life or someone else's.  Take care, drive safe 😊","replyToPid":0}
发表于 2021-10-31 22:49:04 来自手机 | 显示全部楼层
{"replyTo":"","text":"if its calling for chains park. your the captain of your ship \nI've used my tire socks once last winter worked great but","replyToPid":0}
GMT+8, 2026-2-8 05:35 , Processed in 0.110251 second(s), 25 queries .
