查看: 263|回复: 12
Leaving marker or ID lights on at night!
 楼主| 发表于 2021-10-27 09:37:03 来自手机 | 显示全部楼层 |阅读模式
{"text":"I sometimes see truck marker or ID lights on all night when parked along ramp at rest areas. If the truck won’t stay on all night, will that make the battery go dead?","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2021-10-27 18:26:23 来自手机 | 显示全部楼层
{"replyTo":"","text":"I leave my marker lights on when I park anywhere that is not a designated parking spot and any parking spot that I feel is at a high risk of being clipped. I have not had an issue with leaving my lights on with my truck off. but in the cold season if I think it might be an issue I just turn my truck back on after a few hrs then idle for a few hrs then turn off. I then rinse and repeat as needed","replyToPid":0}
禁止发言
发表于 2021-10-27 18:26:09 来自手机 | 显示全部楼层
 楼主| 发表于 2021-10-27 10:34:36 来自手机 | 显示全部楼层
{"replyTo":"","text":"Pete:\n\nThanks! I’m parked along a circular curb at a scenic view area in Utah just short of the Colorado state line on I-70 East! It’s technically not even a rest area! Shut down at 7 pm! Not well lit! Ran out of time and nothing much else around! It’s very dark and windy right now! Nothing but mountains and strong wind and temperatures dropping! There’s a couple other trucks behind me with their market lights on! I just put mine on after reading your comment for safety reasons in case another vehicle goes around the curb and doesn’t see me! If I start my engine it goes off after 5 minutes! I’ll take your word for it that my battery won’t go dead! Once again thanks!","replyToPid":0}
 楼主| 发表于 2021-10-27 17:55:46 来自手机 | 显示全部楼层
{"replyTo":"","text":"Yeah I talked to a mechanic about it! They said it’s against company policy to rig it so engine won’t shut off! ","replyToPid":0}
发表于 2021-10-28 14:34:26 来自手机 | 显示全部楼层
{"replyTo":"","text":" Good evening, hope your day was going smoothly ? Obey the traffic rules also don’t drink while driving. You can hit me up Snapchat::rjesmine20 ","replyToPid":0}
 楼主| 发表于 2021-10-27 17:19:11 来自手机 | 显示全部楼层
766797 发表于 2021-10-27 05:20:39 try to put on trailer brakes and let the tractor brakes pushed in ramp up the idle to 900rpm by cruise control it my help keep engine up...
","text":"Pete:\n\nI tried that! Engine still automatically shuts down after 5 minutes unless I walk up to front seat and push on gas! Then it just keeps shutting down after 5 minutes unless I push down in the gas again! ","replyToPid":450038}
1万
发表于 2021-10-27 21:49:32 来自手机 | 显示全部楼层
766797 发表于 2021-10-27 01:42:51 if the batteries are well maintained and electrical systems to should be no problem and if parked on ramp the markers should be on‼️for YOUR safety
","text":"should be good, especially if you have LED's which use less energy... 👍🇺🇸🙂","replyToPid":450028}
发表于 2021-10-28 09:59:10 来自手机 | 显示全部楼层
{"replyTo":"","text":"Put a water bottle in your shoe,put it on peddle and see if it stays on.I do it bcuz my truck down idle up to 1k rpm by just sitting so I do that at night if I’m running truck.good luck.PS ALWAYs keep those marker lights on on ONs/OFFs ramps NO MATTER WHAT ","replyToPid":0}
发表于 2021-10-31 21:42:44 来自手机 | 显示全部楼层
{"replyTo":"","text":"ID LIGHTS LOL ","replyToPid":0}
GMT+8, 2026-2-8 02:23 , Processed in 0.070472 second(s), 24 queries .
