查看: 399|回复: 9
I want to start taking loads to & from California. most loads say I need to be CARB compliant. How do I become compliant
 楼主| 发表于 2021-10-26 19:17:06 来自手机 | 显示全部楼层 |阅读模式
发表于 2021-10-27 04:59:31 来自手机 | 显示全部楼层
{"replyTo":"","text":"I would find other loads to go to and from instead of driving into communist California","replyToPid":0}
回复 支持 6 反对 1
发表于 2021-11-2 09:46:05 来自手机 | 显示全部楼层
{"replyTo":"","text":"Never start a sentence with “ I want to start taking loads”","replyToPid":0}
发表于 2021-10-26 22:33:38 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"https://air.arb.ca.gov/truckcalc\n\nyour truck engine must be 2010 or newer with a after treatment system.\n\nYour trailer needs to have skirts and low rolling resistant tires.\n\nyour refer needs to be a newer fuel efficient model.\n\nif you're running one truck, it's fairly easy. Make an account, report your equipment,  print out your certificate. \n\nhttps://ww2.arb.ca.gov/our-work/programs/truck-and-bus-regulation\n\nhttps://ssl.arb.ca.gov/trucrs_reporting/login.php\n\n\nif you have a fleet, look to the resources on the website for what you need."}
 楼主| 发表于 2021-10-26 19:50:22 来自手机 | 显示全部楼层
147103 发表于 2021-10-26 11:48:16 I dont run California but twice a year. But to my knowledge.  Carb compliant has to do with year of truck. I'm sure there is drivers who go more often. knows more about that.
","text":"thank you","replyToPid":449978}
 楼主| 发表于 2021-10-26 19:22:57 来自手机 | 显示全部楼层
{"replyTo":"","text":"freightliner cascadia it has the clean idle not sure if that's relevant","replyToPid":0}
禁止发言
发表于 2021-10-26 19:48:16 来自手机 | 显示全部楼层
禁止发言
发表于 2021-10-26 19:20:55 来自手机 | 显示全部楼层
发表于 2021-10-27 04:19:13 来自手机 | 显示全部楼层
{"replyTo":"","text":"Don’t get a truck leasing that’s compliant. They do not like that at all. ","replyToPid":0}
发表于 2021-10-27 16:26:47 来自手机 | 显示全部楼层
1354358 发表于 2021-10-26 14:33:38 https://air.arb.ca.gov/truckcalc\n\nyour truck engine must be 2010 or newer with a after treatment system.\n\nYour trailer needs to have skirts and low rolling resistant tires.\n\nyour refer needs to be a newer fuel efficient model.\n\nif you're running one truck, it's fairly easy. Make an account, report your equipment,  print out your certificate. \n\nhttps://ww2.arb.ca.gov/our-work/programs/truck-and-bus-regulation\n\nhttps://ssl.arb.ca.gov/trucrs_reporting/login.php\n\n\nif you have a fleet, look to the resources on the website for what you need.
","text":"If you come to California. Kum see me at Ta Ontario California.  I give good 💨💨💨💨💨💨💨 job! 😛😛😛","replyToPid":449985}
GMT+8, 2026-4-15 14:02 , Processed in 0.148950 second(s), 25 queries .
