查看: 89|回复: 6
Who knows this?
 楼主| 发表于 2021-10-22 13:44:02 来自手机 | 显示全部楼层 |阅读模式
{"text":"","videos":"[]","link":"{}","pics":"[{\"description\":\"\",\"height\":1600.0,\"name\":\"\",\"url\":\"\",\"width\":720.0}]","canComment":true,"externalShare":false}
发表于 2022-12-1 04:32:50 来自手机 | 显示全部楼层
{"replyTo":"","text":"old school jeep when men where men and had backbones.","replyToPid":0}
1万
发表于 2021-10-24 13:39:08 来自手机 | 显示全部楼层
{"replyTo":"","text":"is that from an old Jeep ?","replyToPid":0}
 楼主| 发表于 2021-10-24 14:03:34 来自手机 | 显示全部楼层
1031233 发表于 2021-10-24 05:39:08 is that from an old Jeep ?
","text":"It is the Shifting pattern for a Mack Two-Stick transmission.","replyToPid":449743}
1万
发表于 2021-10-24 15:07:37 来自手机 | 显示全部楼层
925557 发表于 2021-10-24 06:03:34 It is the Shifting pattern for a Mack Two-Stick transmission.
","text":"what's with the front axle drive and transfer case ?","replyToPid":449750}
发表于 2021-10-27 10:46:38 来自手机 | 显示全部楼层
{"replyTo":"","text":"Okay, seems simple enough, wet = in, dry = out. Low and high range seem fairly standard, Low - 1- 3, High - 1- 3.","replyToPid":0}
发表于 2022-12-21 12:10:09 来自手机 | 显示全部楼层
{"replyTo":"","text":"it's a 5-ton 6x6 military heavy truck","replyToPid":0}
GMT+8, 2026-2-6 05:40 , Processed in 0.094140 second(s), 24 queries .
