查看: 371|回复: 16
Is T-Mobile a good cell phone service for Trucking? Does anyone have any good or bad experiences? Thanks
 楼主| 发表于 2021-10-19 08:36:16 来自手机 | 显示全部楼层 |阅读模式
发表于 2021-10-19 09:16:57 来自手机 | 显示全部楼层
{"replyTo":"","text":"I use T-Mobile and it works fine for me. I spend most of my time out in the middle of nowhere in the desert and there are very few spots I do not get a signal.","replyToPid":0}
发表于 2021-10-20 00:07:54 来自手机 | 显示全部楼层
{"replyTo":"","text":"I have Verizon . It seems to be awesome . Better than Sprint we used to have .","replyToPid":0}
发表于 2021-10-19 09:17:08 来自手机 | 显示全部楼层
{"replyTo":"","text":"I never had any problems with T-mobile no matter where I was the signal was the best..good luck and many safe travels driver","replyToPid":0}
发表于 2021-10-20 13:00:23 来自手机 | 显示全部楼层
{"replyTo":"","text":"we tryed t mobile worked ok till ya step outa the city limits, went back to verizon fast, best service ya ca git fer otr work","replyToPid":0}
发表于 2021-10-23 06:21:35 来自手机 | 显示全部楼层
{"replyTo":"","text":"T-Mobile always used to get wonky around Utah and the salt flats and Nevada, went to Verizon, issues deleted ","replyToPid":0}
发表于 2021-10-20 21:02:07 来自手机 | 显示全部楼层
{"replyTo":"","text":"Verizon.  I recommend","replyToPid":0}
发表于 2021-10-19 17:48:45 来自手机 | 显示全部楼层
{"replyTo":"","text":"I use Visible by Verizon for my truck’s always on Wi-Fi.  Unlimited and unthrottled hot spot for $25 per month (It reduces from $40 to $25 just by joining a party, there are lots of parties to join)\n\nCheck out this page: https://www.visible.com/get/3shvtv, it has all the info you need to know about joining Visible. When you use my friend code, 3shvtv, you’ll get your first month of service for only $5!","replyToPid":0}
发表于 2021-10-28 08:13:14 来自手机 | 显示全部楼层
{"replyTo":"","text":"T-mobile works great for me.. never have issues","replyToPid":0}
发表于 2021-10-22 09:19:06 来自手机 | 显示全部楼层
{"replyTo":"","text":"no not at all.","replyToPid":0}
 楼主| 发表于 2021-10-19 12:24:11 来自手机 | 显示全部楼层
925557 发表于 2021-10-19 01:16:57 I use T-Mobile and it works fine for me. I spend most of my time out in the middle of nowhere in the desert and there are very few spots I do not get a signal.
","text":"Thank You ","replyToPid":449140}
 楼主| 发表于 2021-10-19 12:26:53 来自手机 | 显示全部楼层
1066054 发表于 2021-10-19 01:17:08 I never had any problems with T-mobile no matter where I was the signal was the best..good luck and many safe travels driver
","text":"Thank You ","replyToPid":449141}
发表于 2021-10-20 08:49:31 来自手机 | 显示全部楼层
{"replyTo":"","text":"I used it for a year it was away but thinking of going back to Verizon I don't like this new 5g phone voice has become bad and the phone heats up but the 4g phone was good","replyToPid":0}
GMT+8, 2026-4-18 02:50 , Processed in 0.160317 second(s), 25 queries .
