查看: 144|回复: 3
Pretrip inspections
 楼主| 发表于 2021-10-18 21:06:46 来自手机 | 显示全部楼层 |阅读模式
{"text":"The longer I drive, the more I realize the importance of pretrip inspections. Especially with trailers that I have to pick up! Flat tires especially! And you can’t tell unless you pound the tires! Also I’ve found missing mud flaps, airlines and wires hanging on ground, lights not working, trl doors that won’t shut cause of bent lock rods! Also important to walk inside mt trls to check for holes in ceiling, walls, and floor! \n\nSeems like I get the worse luck with picking up mt trls! Always a flat tire that you can’t see unless you pound them or something else wrong with it! \n\nDoes anyone else get bad luck with picking up defected trls?","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
1万
发表于 2021-10-18 21:23:39 来自手机 | 显示全部楼层
{"replyTo":"","text":"that's probably because you pull the same trailer and maintain your equipment 👍","replyToPid":449066}
发表于 2021-10-21 11:54:45 来自手机 | 显示全部楼层
{"replyTo":"","text":"I feel it goes in waves of about a month or two, and rotates through the company. some months I get crap trailers or truck issues, then I won't have issues for a few months","replyToPid":0}
发表于 2021-10-21 17:42:26 来自手机 | 显示全部楼层
{"replyTo":"","text":"nope, no issues here, always have new trailers","replyToPid":0}
GMT+8, 2026-2-8 05:55 , Processed in 0.063592 second(s), 23 queries .
