查看: 442|回复: 13
Steer axle issue
 楼主| 发表于 2021-10-17 02:45:56 来自手机 | 显示全部楼层 |阅读模式
{"text":"Can anybody for the love of God help me out with a good advise, suggestion or opinion what to do with my truck.\nI got Volvo 2016 and I’ve been dealing with the same problem over a year now.\nMy steer axle, actually my steering wheel is shaking and moving so hard left and right when I hit the brakes.\nI have replaced:\n1. King pins\n2. Brake shoes and drums (original from Volvo)\n3. Shocks\n4. Drag link\n5. Both leaf springs \n6. Gearbox \n7. New Michelin tires (balanced them as well)\n8. Really good alignment (for 3 axle)\n9. Central bearing as well\n\nAnd it’s shaking and moving like I did not touch any of this parts from the list.\nI’m sick and tired, and don’t know what to do anymore.I spent more than 20k on it.\n\nI really appreciate any opinion or advise.\nThank you so much.","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2021-10-17 02:50:54 来自手机 | 显示全部楼层
{"replyTo":"","text":"sounds like you did almost everything except get a new axle. That truck probably ran off the road.","replyToPid":0}
回复 支持 2 反对 7
发表于 2021-10-17 04:54:51 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"and choose a different mechanic if you've been going to the same one...get an ase certified mechanic."}
回复 支持 0 反对 8
发表于 2021-10-17 05:00:30 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"if i were you, i would get the truck on jacks, get a dial indicator,  and check the out of round of your axle.\n\nhttps://youtu.be/W4e-lElEnZA\n\nthat shaking is from an imbalance.  you need to find out what is out of round.\n\nstart at the very basic.\n\nspindle and bearings. then drums, and then check your rims. check both the roundness, circle, and thrust, in and out, measurements.\n\ncheck the brake system because it happens when you brake. but other loose parts could be possible."}
回复 支持 0 反对 8
发表于 2021-10-17 09:06:13 来自手机 | 显示全部楼层
1348553 发表于 2021-10-16 20:54:51 and choose a different mechanic if you've been going to the same one...get an ase certified mechanic.
","text":"Don't ask Accusme. Few months ago. He was asking how to change oil on his swift truck","replyToPid":448811}
发表于 2021-10-17 16:24:58 来自手机 | 显示全部楼层
{"replyTo":"","text":"Good evening, hope your day was going smoothly ? Obey the traffic rules also don’t drink while driving. You can hit me up Snapchat::rjesmine20 ","replyToPid":0}
回复 支持 0 反对 3
发表于 2021-10-17 09:33:51 来自手机 | 显示全部楼层
1348553 发表于 2021-10-16 21:00:30 if i were you, i would get the truck on jacks, get a dial indicator,  and check the out of round of your axle.\n\nhttps://youtu.be/W4e-lElEnZA\n\nthat shaking is from an imbalance.  you need to find out what is out of round.\n\nstart at the very basic.\n\nspindle and bearings. then drums, and then check your rims. check both the roundness, circle, and thrust, in and out, measurements.\n\ncheck the brake system because it happens when you brake. but other loose parts could be possible.
","text":"Tell him what your best at.......... 💄👠💋🩱.","replyToPid":448812}
发表于 2021-10-17 08:53:28 来自手机 | 显示全部楼层
","text":"Drivers im working Ta truckstop tonight! Come get a 💨💨💨💨 job by Acusme! I will do your 🐕 for free","replyToPid":448812}
发表于 2021-10-17 12:03:00 来自手机 | 显示全部楼层
838050 发表于 2021-10-16 19:19:34 Thank you for your comment sir.\nYes, pretty much everything replaced.Only steering column I haven’t replaced yet.\nI’m just wondering if that mehanic did something wrong when he was replacing a leaf springs.I have no idea anymore.\nAnd I bought that truck 2018 with low mileage from my friend, and I never hit nothing with that truck.\nIt just started, worse and worse.So I’m replacing steer tires and doing the alignment every 4,5 weeks.Terrible.
","text":"if you're replacing wheels every 4-5 weeks, it may be an alignment problem that can't be fixed without replacing the axle. i replace my tires every 2 years.","replyToPid":448802}
发表于 2021-10-17 09:06:43 来自手机 | 显示全部楼层
1340456 发表于 2021-10-17 00:53:28 Drivers im working Ta truckstop tonight! Come get a 💨💨💨💨 job by Acusme! I will do your 🐕 for free
","text":"🤣👊","replyToPid":448830}
发表于 2021-10-19 09:49:40 来自手机 | 显示全部楼层
{"replyTo":"","text":"Try  MD alignment  there based of Des Moines Iowa","replyToPid":0}
 楼主| 发表于 2021-10-17 03:19:34 来自手机 | 显示全部楼层
1348553 发表于 2021-10-16 18:50:54 sounds like you did almost everything except get a new axle. That truck probably ran off the road.
","text":"Thank you for your comment sir.\nYes, pretty much everything replaced.Only steering column I haven’t replaced yet.\nI’m just wondering if that mehanic did something wrong when he was replacing a leaf springs.I have no idea anymore.\nAnd I bought that truck 2018 with low mileage from my friend, and I never hit nothing with that truck.\nIt just started, worse and worse.So I’m replacing steer tires and doing the alignment every 4,5 weeks.Terrible.","replyToPid":448800}
发表于 2021-10-17 09:25:58 来自手机 | 显示全部楼层
","text":"https://m.activebeat.com/your-health/7-symptoms-of-narcissistic-personality-disorder/?utm_medium=cpc&utm_source=google_search_network&utm_campaign=AB_GGL_US_MOBI-REBOOT&utm_content=g_m_495767953395&utm_term=define+narcissistic+personality+disorder&placement=dsa-300116141457&utm_acid=2456153964&utm_caid=12229891664&utm_agid=115103889257&utm_os=&utm_pagetype=var-multi&device=m&gclid=CjwKCAjw8KmLBhB8EiwAQbqNoFH3CSwvAkMaXfnpvMEQOuvyGJ_wiOk6XLr9ILSnPbiOgNHhKAbB2RoCiYoQAvD_BwE","replyToPid":448812}
GMT+8, 2026-4-15 17:37 , Processed in 0.136642 second(s), 24 queries .
