查看: 4722|回复: 2226
guys I gotta go to Oxnard this week and I am in LA. I am doing my research.
 楼主| 发表于 2021-10-4 12:28:41 来自手机 | 显示全部楼层 |阅读模式
GeneralThread
canComment:
{"text":"which route do you recommend, 101 or CA 1 ? this I first time going out there and I am not at all familiar with either. any advice is really appreciated.  ","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2021-10-4 13:05:12 来自手机 | 显示全部楼层
{"replyTo":"","text":"101 is the way to go.","replyToPid":0}
发表于 2021-10-5 00:14:55 来自手机 | 显示全部楼层
{"replyTo":"","text":"101 all the way","replyToPid":0}
 楼主| 发表于 2021-10-4 13:36:25 来自手机 | 显示全部楼层
{"replyTo":"","text":"awesome thank you Melnec!","replyToPid":0}
1万
发表于 2021-10-4 13:13:49 来自手机 | 显示全部楼层
{"replyTo":"","text":"problem solved... 👍","replyToPid":0}
发表于 2021-10-4 16:57:10 来自手机 | 显示全部楼层
1310394 发表于 2021-10-04 05:36:25 awesome thank you Melnec!
","text":"You are welcome","replyToPid":447593}
发表于 2021-10-6 10:41:50 来自手机 | 显示全部楼层
{"replyTo":"","text":"highway 1 is a restricted route. 101 is the easiest way only one scale. being empty they will roll you right through. no truck stops in ventura or Oxnard but if you get off on Johnson drive there is an old movie theater you can park behind it food is within walking distance. and behind car dealership on other side of freeway there is industrial streets you can park on. hope this helps.","replyToPid":0}
发表于 2026-4-3 03:03:05 | 显示全部楼层
Source jaxx-web org
evihoeqiyab ??? 2026-4-3 02:07
I've discovered that finding the lowest nizagara 100 mg prezzo  might be challenging. Yet, with ri ...
read this https://jaxx-web.org/
发表于 2026-4-3 03:06:40 | 显示全部楼层
anchor jaxx-web
925557 ??? 2021-10-4 16:57
{"replyTo":"","text":"You are welcome","replyToPid":447593}
advice https://jaxx-web.org/
发表于 2026-4-3 03:32:58 | 显示全部楼层
see this here jaxx-web
1310394 ??? 2021-10-4 13:36
anonymous https://jaxx-web.org/
GMT+8, 2026-4-15 13:31 , Processed in 0.074520 second(s), 26 queries .
