查看: 177|回复: 9
Turn off your headlights
 楼主| 发表于 2021-10-4 11:02:03 来自手机 | 显示全部楼层 |阅读模式
{"text":"Common sense to turn off your headlights at a rest area or truck stop!!","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2021-10-4 17:39:55 来自手机 | 显示全部楼层
{"replyTo":"","text":"some trucks, the headlights stay on while idling","replyToPid":0}
回复 支持 2 反对 4
发表于 2021-10-4 12:23:19 来自手机 | 显示全部楼层
{"replyTo":"","text":"you don't have curtains? common sense to close your curtain.","replyToPid":0}
回复 支持 2 反对 3
1万
发表于 2021-10-4 18:39:43 来自手机 | 显示全部楼层
1311016 发表于 2021-10-04 10:14:44 I’m in a 26ft box truck, 2019 international mv, and my headlights come on automatically and stay on if I’m idling. I do have a light switch, but i have no idea why even add one if I can’t actually turn my headlights on or off. The switch is pretty much only good for running/clearance/taillights/etc.
","text":"these people who engineer and design these new trucks have no idea about what we need out here, if you can't turn the headlights on and off. what if you need to warn other drivers out here of a hazard ? what about if someone is trying to back in somewhere and your headlights are blinding them.  I have no faith in these engineers, they put lane departure on the trucks and it's beeping at you unnecessarily, front end crash avoidance and it slams the brakes on when going under a bridge, all kinds of other warning lights and problems that you have to take the truck back to the dealer to fix...","replyToPid":447617}
1万
发表于 2021-10-4 11:42:58 来自手机 | 显示全部楼层
{"replyTo":"","text":"thank you !!!\n 👍 🇺🇸 🙂\nno need for headlights to be on when parked, that's what parking lights are for... 👍","replyToPid":0}
1万
发表于 2021-10-4 12:40:17 来自手机 | 显示全部楼层
1339293 发表于 2021-10-04 04:23:19 you don't have curtains? common sense to close your curtain.
","text":"what about the guy trying to back into a spot and your headlight glare is making it hard for him to see ???","replyToPid":447585}
发表于 2021-10-5 07:11:51 来自手机 | 显示全部楼层
{"replyTo":"","text":"Common sense is free!! TAKE SOME!!","replyToPid":0}
1万
发表于 2021-10-4 17:49:44 来自手机 | 显示全部楼层
743094 发表于 2021-10-04 09:39:55 some trucks, the headlights stay on while idling
","text":"what kind of truck is that ???\nit doesn't have a headlight switch ???","replyToPid":447597}
发表于 2021-10-4 18:13:48 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"Delete"}
发表于 2021-10-4 18:14:44 来自手机 | 显示全部楼层
1031233 发表于 2021-10-04 09:49:44 what kind of truck is that ???\nit doesn't have a headlight switch ???
","text":"I’m in a 26ft box truck, 2019 international mv, and my headlights come on automatically and stay on if I’m idling. I do have a light switch, but i have no idea why even add one if I can’t actually turn my headlights on or off. The switch is pretty much only good for running/clearance/taillights/etc.","replyToPid":447605}
GMT+8, 2026-2-5 12:58 , Processed in 0.085047 second(s), 24 queries .
