查看: 198|回复: 7
2018 t680 shifts hard
 楼主| 发表于 2021-10-3 00:40:37 来自手机 | 显示全部楼层 |阅读模式
{"text":"I just switched from a 2019 t680 with the 12 speed to a 2018 t680 with the 10 speed. both automatic. I notice the 2018 10 speed seems to shift hard in the lower gears. especially when starting from a stop. is this just normal with the 10 speed and I need to get used to it?\n\nI called the kenworth dealership and they said there would be a light on the dash if there was a problem. the 12 speed was a lot smoother. looking to see if it's worth taking into a shop to get looked at.\n\nthanks","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
1万
发表于 2021-10-3 12:06:30 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"(I was replying to Jack Burton)\nhe said it is an automatic transmission...\nthere is no clutch... \nand it shifts when it wants to...\n\nthat's the problem...\nit's an automatic...\n\n 🙂 🇺🇸 👍"}
发表于 2021-10-3 02:03:30 来自手机 | 显示全部楼层
{"replyTo":"","text":"company driver? if there was a problem there would be a light on the dash. owner op? change your fluid. see if that helps","replyToPid":0}
发表于 2021-10-3 11:44:37 来自手机 | 显示全部楼层
{"replyTo":"","text":"get a volco I shift","replyToPid":0}
发表于 2021-10-3 03:31:02 来自手机 | 显示全部楼层
{"replyTo":"","text":"Just be careful \nThat’s all I’ve got to say","replyToPid":0}
发表于 2021-10-3 11:20:09 来自手机 | 显示全部楼层
{"replyTo":"","text":"RPMs too high when you shifty maybe? Are you floating or clutching ","replyToPid":0}
 楼主| 发表于 2021-10-4 22:51:30 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"I called kenworth. they said if there was a problem it would have a light on the dash. \n\nwent home for 2 days and when I started the truck and put it in gear it took a bit for the transmission to realize I had my foot on the acceleration and kicked into the gear. then it was going up in speed super slow like it was still warming up. alot of play in the pedal before it registers."}
发表于 2021-10-10 16:11:40 来自手机 | 显示全部楼层
{"replyTo":"","text":"Good evening, hope your day was going smoothly ? Obey the traffic rules also don’t drink while driving. You can hit me up Snapchat::rjesmine20 ","replyToPid":0}
GMT+8, 2026-4-17 21:55 , Processed in 0.086448 second(s), 24 queries .
