查看: 314|回复: 11
Need help
 楼主| 发表于 2021-10-2 00:42:32 来自手机 | 显示全部楼层 |阅读模式
{"text":"Anyone have some proven ways to handle swelling feet and ankles? Thanks","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2021-10-2 10:52:42 来自手机 | 显示全部楼层
{"replyTo":"","text":"To get rid of the swelling... get out of your mom's basement and stop scamming.","replyToPid":0}
回复 支持 4 反对 1
发表于 2021-10-2 03:12:46 来自手机 | 显示全部楼层
{"replyTo":"","text":"Got to stop sugar ingestion and meat and salt. Legs up whenever possible   Stop eating. Maybe with fastening one day a week you might get cure. 👍👍🙏","replyToPid":0}
发表于 2021-10-2 03:42:15 来自手机 | 显示全部楼层
{"replyTo":"","text":"Is the swelling there all the time or only after you've driven all day? The reason I ask is becuz sitting all day driving results in gravity to cause blood to pool and causes swelling. If the swelling doesn't exist when ur not behind the wheel all day then more than likely this is the cause. Lack of blood flow causes swelling.. However, if ur legs and ankles stay swollen all the time then there is cause to monitor ur blood pressure with a cuff you can buy at Walmart. Keep a log of ur readings and see if there is an elevation on a regular basis and if there is see your doctor and get evaluated for high blood pressure. Drinking more water and eating less salt and moving around more (I know it's tough when u have to drive all day) will help if it's a simple a lack of blood flow issue.\n*disclaimer - this is not meant to replace the expert care of a medical professional nor is it meant as a diagnosis. Seek medical care if you feel u have a condition needing attention *","replyToPid":0}
发表于 2021-10-2 01:38:54 来自手机 | 显示全部楼层
{"replyTo":"","text":"Nigerian","replyToPid":0}
1万
发表于 2021-10-2 21:24:51 来自手机 | 显示全部楼层
1317841 发表于 2021-10-01 17:39:00 https://tineye.com/search/2c72f7eb3daeeb20b8cc42383b77dcc2046e37aa?sort=score&order=desc&page=1
","text":"👍👍👍","replyToPid":447333}
发表于 2021-10-2 03:18:37 来自手机 | 显示全部楼层
{"replyTo":"","text":"Sounds like high blood pressure. Dr can give you meds to treat it, DOT legal too. Have to cut down the sodium intake for sure. Compression socks will help too,  but feet and ankle sweeling is usually a sign of high blood pressure and water retention","replyToPid":0}
发表于 2021-10-2 01:39:00 来自手机 | 显示全部楼层
{"replyTo":"","text":"https://tineye.com/search/2c72f7eb3daeeb20b8cc42383b77dcc2046e37aa?sort=score&order=desc&page=1","replyToPid":0}
发表于 2021-10-2 09:38:37 来自手机 | 显示全部楼层
{"replyTo":"","text":"Compression socks.","replyToPid":0}
发表于 2021-10-2 12:33:19 来自手机 | 显示全部楼层
{"replyTo":"","text":"drastically reduce your sodium intake and increase water intake","replyToPid":0}
 楼主| 发表于 2021-10-2 14:06:11 来自手机 | 显示全部楼层
723315 发表于 2021-10-02 04:33:19 drastically reduce your sodium intake and increase water intake
","text":"Thanks will give it a trial ","replyToPid":447400}
GMT+8, 2026-4-17 21:55 , Processed in 0.108909 second(s), 24 queries .
