查看: 143|回复: 3
how to cancel
 楼主| 发表于 2021-9-20 15:21:20 来自手机 | 显示全部楼层 |阅读模式
{"text":"How do you cancel this service?","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
1万
发表于 2021-9-20 16:01:18 来自手机 | 显示全部楼层
{"replyTo":"","text":"you better stick around driver...\nhow else are you going to learn all the ABC's of trailer truckin' in 2021\n 🙂 🇺🇸 👍","replyToPid":0}
回复 支持 4 反对 1
发表于 2021-9-21 11:06:28 来自手机 | 显示全部楼层
{"replyTo":"","text":"Take a hammer 🔨 to your screen…. That will cancel everything ","replyToPid":0}
发表于 2021-9-25 20:39:58 来自手机 | 显示全部楼层
{"replyTo":"","text":"after getting loaded with a heavy load carefully place your phone underneath your drive tires before leaving the shipper. It is extremely important for you to lean the phone up against the tire so that it does the job properly.","replyToPid":0}
GMT+8, 2026-2-8 14:25 , Processed in 0.054152 second(s), 24 queries .
