查看: 280|回复: 13
ELD taking 7 hrs to offload 1st 5hrs to get a door n 2 at the door is it on duty/del? it's eating up drive n shift time
 楼主| 发表于 2021-9-16 01:56:08 来自手机 | 显示全部楼层 |阅读模式
发表于 2021-9-20 18:53:13 来自手机 | 显示全部楼层
766797 发表于 2021-09-15 22:34:33 you need to learn the split rule ......‼️👍🦕
","text":"is that a thing? pc to customer due to traffic? thought couldn't advance load on pc? isn't that a violation?","replyToPid":445739}
发表于 2021-9-16 23:20:44 来自手机 | 显示全部楼层
{"replyTo":"","text":"this is why I drive an  elog exempt truck. lol","replyToPid":0}
发表于 2021-9-16 02:44:35 来自手机 | 显示全部楼层
{"replyTo":"","text":"Welcome to trucking if you edit your logs for 15 minutes on duty unloading then go into sleeper mode after 7 hrs in the sleeper it will reset your 14hr clock","replyToPid":0}
发表于 2021-9-16 03:39:11 来自手机 | 显示全部楼层
{"replyTo":"","text":"It depends on how many hrs you drove already for the day experience comes with knowledge. Everyone was a rookie at one time in life","replyToPid":0}
 楼主| 发表于 2021-9-16 03:16:10 来自手机 | 显示全部楼层
88424 发表于 2021-09-15 18:44:35 Welcome to trucking if you edit your logs for 15 minutes on duty unloading then go into sleeper mode after 7 hrs in the sleeper it will reset your 14hr clock
","text":"wow n my drive time will still keep on going? omg this is crazy meaning I won't have enough drive time to even get to a truck stop lol used my PC 1hr in traffic before getting to customer real newbie to this!","replyToPid":445708}
发表于 2021-9-16 04:43:13 来自手机 | 显示全部楼层
{"replyTo":"","text":"you also have that safe haven option, most carriers have an allowance up to 50 miles but take photos of the places you stopped at if full to cover your bases with DOT","replyToPid":0}
发表于 2021-9-16 06:45:14 来自手机 | 显示全部楼层
{"replyTo":"","text":"Yes cover your bases the best way to document is when you find no parking at wherever you are click on the driving option and the keyboard should pop up type in there no parking here and click save then ok. That automatically adds a notation to your drive line and the coordinates is logged","replyToPid":0}
发表于 2021-9-16 07:09:43 来自手机 | 显示全部楼层
1248444 发表于 2021-09-15 20:43:13 you also have that safe haven option, most carriers have an allowance up to 50 miles but take photos of the places you stopped at if full to cover your bases with DOT
","text":"There’s no such thing as “the safe haven option” unless you’re hauling very specific hazmat. Don’t believe everything you hear at the buffet.","replyToPid":445726}
发表于 2021-9-16 08:32:32 来自手机 | 显示全部楼层
{"replyTo":"","text":"Wth is eld? Does my prevost have one?","replyToPid":0}
发表于 2021-9-16 14:26:34 来自手机 | 显示全部楼层
{"replyTo":"","text":"if you're out of HOS due to shipper/receiver hold up you can legally drive until you find a place to park and DOT will not sight you for it,  it's happened to me a few times","replyToPid":0}
发表于 2021-9-16 22:26:30 来自手机 | 显示全部楼层
936953 发表于 2021-09-15 23:09:43 There’s no such thing as “the safe haven option” unless you’re hauling very specific hazmat. Don’t believe everything you hear at the buffet.
","text":"There is two different \"safe havens\" :  FMCSA Section 397.5 is in regards to Attendance and Surveillance which is what you are referring to about hazmat loads being in a safe place. Then there is also PC (personal conveyance) Safe Haven. This option is when a driver does not have enough hours to find a safe place to park, they are allowed to use this per DOT as long as you follow your company requirements for how to log this usage. Clearly the two could be misunderstood since they contain the same verbiage and could possibly of caused the confusion. Hopefully this helps clear this topic up for anyone who may question it. (not trying to be a smarta** just trying to make sure ppl have the correct information as it seems like seasoned drivers like to misinform newbies). Stay safe y'all 😉","replyToPid":445748}
GMT+8, 2026-4-17 21:55 , Processed in 0.097094 second(s), 24 queries .
