查看: 292|回复: 11
question drivers
 楼主| 发表于 2021-9-15 19:37:12 来自手机 | 显示全部楼层 |阅读模式
{"text":"are dot officers allowed to open the locked trailer doors without a pappper sighned or sum","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2021-9-15 20:37:15 来自手机 | 显示全部楼层
{"replyTo":"","text":"they can do whatever the F they want, and if you don't support the blue, then F you too.","replyToPid":0}
回复 支持 3 反对 4
发表于 2021-9-15 21:13:09 来自手机 | 显示全部楼层
1074173 发表于 2021-09-15 12:50:59 They can inspect cargo. If sealed they will break seal, inspect cargo and re seal trailer and give you a document of what took place to give to the receiver. \nYou can argue and you’ll probably be in the right. But why jam up your day for cargo that isn’t yours to begin with.
","text":"state your name, company DOT, so i can report your u professional behavior.","replyToPid":445621}
回复 支持 1 反对 4
发表于 2021-9-15 20:50:59 来自手机 | 显示全部楼层
{"replyTo":"","text":"They can inspect cargo. If sealed they will break seal, inspect cargo and re seal trailer and give you a document of what took place to give to the receiver. \nYou can argue and you’ll probably be in the right. But why jam up your day for cargo that isn’t yours to begin with. ","replyToPid":0}
发表于 2021-9-15 19:42:12 来自手机 | 显示全部楼层
{"replyTo":"","text":"They can if they have a good reason for it ","replyToPid":0}
回复 支持 4 反对 1
发表于 2021-9-16 01:58:47 来自手机 | 显示全部楼层
{"replyTo":"","text":"They can and will, but will give some form of documentation and seal the load with their own seal.","replyToPid":0}
发表于 2021-9-15 21:11:19 来自手机 | 显示全部楼层
{"replyTo":"","text":"trust your cargo with people who don't give a F about your cargo. what a fkin professional 👏 👌.","replyToPid":0}
 楼主| 发表于 2021-9-16 05:02:31 来自手机 | 显示全部楼层
","text":"appriciate you","replyToPid":445621}
 楼主| 发表于 2021-9-16 05:01:50 来自手机 | 显示全部楼层
936953 发表于 2021-09-15 17:58:47 They can and will, but will give some form of documentation and seal the load with their own seal.
","text":"thank you smokin joe","replyToPid":445698}
 楼主| 发表于 2021-9-16 05:02:01 来自手机 | 显示全部楼层
1327036 发表于 2021-09-15 13:13:09 state your name, company DOT, so i can report your u professional behavior.
","text":"thanks","replyToPid":445634}
GMT+8, 2026-4-18 01:03 , Processed in 0.091419 second(s), 24 queries .
