查看: 211|回复: 9
Give Respect, Get Respect
 楼主| 发表于 2021-9-11 03:42:14 来自手机 | 显示全部楼层 |阅读模式
{"text":"Let's make this happen. If you use a truck stop Shower that you didn't pay out of your own pocket, If it was Free for You more or less, you have NO EXCUSE.  LEAVE A TIP FOR THOSE WHO CLEAN UP AFTER YOU!!! Common Courtesy Folks. I'd hate like Hell to clean up after my Fellow Driver. That little bit, will pay you back in several ways.  Cleaner Facilities,  Friendlier Staff, A Self Satisfaction from doing a Kindness to your fellow man. More reasons that you should than you shouldn't.  Let's Make it Happen ","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2021-9-11 04:43:32 来自手机 | 显示全部楼层
{"replyTo":"","text":"If the shower is clean I leave a tip, if not, I don't. Same with the waitress, good service gets a tip.","replyToPid":0}
回复 支持 6 反对 0
发表于 2021-9-14 09:18:20 来自手机 | 显示全部楼层
{"replyTo":"","text":"Treat people the way you want to be treated. Just because the bathroom attendant has a shittier job then you, he doesn’t have to be treated that way. Pay it forward. ","replyToPid":0}
发表于 2021-9-12 10:09:22 来自手机 | 显示全部楼层
{"replyTo":"","text":"Nothing is ever free","replyToPid":0}
发表于 2021-9-13 08:33:20 来自手机 | 显示全部楼层
{"replyTo":"","text":"us truck drivers don't get tips for supplying this world, we only get treated like lower than the value of dirt\nSO THAT BEING SAID I DON'T LEAVE TIPS FOR ANYONE","replyToPid":0}
发表于 2021-9-12 03:33:03 来自手机 | 显示全部楼层
{"replyTo":"","text":"I won't tip but I will always tell them thank you.","replyToPid":0}
发表于 2021-9-11 04:04:13 来自手机 | 显示全部楼层
{"replyTo":"","text":"👍","replyToPid":0}
发表于 2021-9-11 06:27:59 来自手机 | 显示全部楼层
753289 发表于 2021-09-10 20:43:32 If the shower is clean I leave a tip, if not, I don't. Same with the waitress, good service gets a tip.
","text":"Agreed ","replyToPid":445058}
发表于 2021-9-11 10:28:37 来自手机 | 显示全部楼层
{"replyTo":"","text":"Man I never thought of this but I’m going to start leaving some coffee money. Great advice brother! ","replyToPid":0}
发表于 2021-9-14 06:27:34 来自手机 | 显示全部楼层
{"replyTo":"","text":"It’s not free it’s added into the cost of fuel.There’s a reason that the major truck stops are 30-40 cents higher than everyone else.","replyToPid":0}
GMT+8, 2026-2-8 18:52 , Processed in 0.053333 second(s), 24 queries .
