查看: 149|回复: 6
Power supply?
 楼主| 发表于 2021-9-9 21:36:52 来自手机 | 显示全部楼层 |阅读模式
{"text":"What do you guys with these idle shut off trucks do for consistent power on your 34s? I have a company truck fully equipped with an inverter and a nice little tv that are essentially useless to me unless I can idle my truck which only happens if the temperature is above 80°. Can't modify the truck, company won't turn off idle control. I run reefer and tried hooking my unit up to my battery terminals which oddly enough seemed to do nothing for my inverter power. Anybody out there run into this issue?","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2021-9-9 22:34:08 来自手机 | 显示全部楼层
{"replyTo":"","text":"push in the yellow and  pull the red . hint hint","replyToPid":0}
发表于 2021-9-10 12:55:24 来自手机 | 显示全部楼层
{"replyTo":"","text":"use the cruise to idle it up...","replyToPid":0}
 楼主| 发表于 2021-9-9 22:41:35 来自手机 | 显示全部楼层
698360 发表于 2021-09-09 14:34:08 push in the yellow and  pull the red . hint hint
","text":"Tried that once. You would think it would stay running but even that didn't work.","replyToPid":444874}
发表于 2021-9-9 21:40:19 来自手机 | 显示全部楼层
{"replyTo":"","text":"get yourself a small generator.","replyToPid":0}
 楼主| 发表于 2021-9-9 22:39:41 来自手机 | 显示全部楼层
1309412 发表于 2021-09-09 13:40:19 get yourself a small generator.
","text":"There's an idea. I'm going home Friday so I'll do some shopping","replyToPid":444867}
发表于 2021-9-10 19:45:25 来自手机 | 显示全部楼层
","text":"just make sure it's a inverter generator","replyToPid":444867}
GMT+8, 2026-2-8 19:12 , Processed in 0.049287 second(s), 24 queries .
