查看: 93|回复: 2
The joys of being a trucker and a farmer
 楼主| 发表于 2021-9-9 01:06:37 来自手机 | 显示全部楼层 |阅读模式
{"text":"it's a great job but sucks when you can't see the rows","videos":"[]","link":"{}","pics":"[{\"description\":\"\",\"height\":2016.0,\"name\":\"\",\"url\":\"\",\"width\":1512.0}]","canComment":true,"externalShare":false}
发表于 2021-9-10 20:00:58 来自手机 | 显示全部楼层
{"replyTo":"","text":"If you plant with gps, go to the heading screen and save your heading numbers. For the rest of the year you can replicate your heading and go to the parallel swath adjust to get centered on your rows. You can cultivate, spray, and harvest with the same numbers and your equipment will keep you in the right track. ","replyToPid":0}
 楼主| 发表于 2021-9-17 19:43:47 来自手机 | 显示全部楼层
{"replyTo":"","text":"yeah unfortunately we put a globe on the planter too try to eliminate the sway of the drag of the planter and the globe on the tractor and the globe on the planter fought each other 445 Fields until they got it working right and this was the result of the rows every pass has a wobble or a sway to it all the way across the field","replyToPid":0}
GMT+8, 2026-2-5 12:59 , Processed in 0.057243 second(s), 23 queries .
