查看: 369|回复: 6
Bobtail Driving
 楼主| 发表于 2021-9-8 03:34:48 来自手机 | 显示全部楼层 |阅读模式
{"text":"I am a new driver with only 30 days of driving experience. I am about to drive 10 hours in a bobtail. This seems unsafe. Is there anything I should watch for when driving a bobtail that is dangerous? I feel very front heavy, obviously, and am wary of going highway speeds around curves.","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2021-9-8 03:48:35 来自手机 | 显示全部楼层
{"replyTo":"","text":"Unless it raining, hammer down. ","replyToPid":0}
发表于 2021-9-8 03:43:40 来自手机 | 显示全部楼层
{"replyTo":"","text":"so you will be safe to take curves and things in a bob. when going into a tight curve you need to keep your speeds slower. also dont use full jake break when bobing without a trailer cause its a great way of kissing the dash. the only big worry with bob tailing with high winds. other than that its like driving a super large car. you'll do fine. when in doubt go slow. \n\nyou can go as slow as you want as many times as you want. you can only go too fast once.","replyToPid":0}
发表于 2021-9-8 03:43:43 来自手机 | 显示全部楼层
{"replyTo":"","text":"just cruise easy.","replyToPid":0}
发表于 2021-9-8 08:53:05 来自手机 | 显示全部楼层
{"replyTo":"","text":"Only different thing to be done is give yourself more room for stopping. You don’t have the traction on your drives like you would if you had 34k on them. \n\nKeep it between the ditches and hammer down. You’ll be fine","replyToPid":0}
发表于 2021-9-9 22:14:05 来自手机 | 显示全部楼层
{"replyTo":"","text":"60 mph","replyToPid":0}
 楼主| 发表于 2021-9-8 03:47:22 来自手机 | 显示全部楼层
666627 发表于 2021-09-07 19:43:40 so you will be safe to take curves and things in a bob. when going into a tight curve you need to keep your speeds slower. also dont use full jake break when bobing without a trailer cause its a great way of kissing the dash. the only big worry with bob tailing with high winds. other than that its like driving a super large car. you'll do fine. when in doubt go slow. \n\nyou can go as slow as you want as many times as you want. you can only go too fast once.
","text":"Thank you very much. I recognize that I have very little training and experience and my goal is keeping everyone safe.","replyToPid":444638}
GMT+8, 2026-4-16 06:17 , Processed in 0.123802 second(s), 24 queries .
