查看: 276|回复: 18
Every time I hit a bump my truck lose power and my speedometer jumps around then power come back anyone know what’swrong
 楼主| 发表于 2019-6-8 13:27:47 来自手机 | 显示全部楼层 |阅读模式
发表于 2019-6-8 14:54:24 来自手机 | 显示全部楼层
{"replyTo":"","text":"it could be a couple of things I had that happen as well. where the main wiring harness connects to the computer under the hood is where I would check first. mine had come loose. but this is just one of many options. the battery cables also could cause that as bombon stated... good luck man.","replyToPid":0}
发表于 2019-6-8 13:46:33 来自手机 | 显示全部楼层
{"replyTo":"","text":"i had similar issue...check connections on the batteries or alternator.","replyToPid":0}
 楼主| 发表于 2019-6-8 14:07:03 来自手机 | 显示全部楼层
640064 发表于 2019-06-08 05:46:33 i had similar issue...check connections on the batteries or alternator.
","text":"Ok will do","replyToPid":59465}
 楼主| 发表于 2019-6-8 14:58:24 来自手机 | 显示全部楼层
713691 发表于 2019-06-08 06:54:24 it could be a couple of things I had that happen as well. where the main wiring harness connects to the computer under the hood is where I would check first. mine had come loose. but this is just one of many options. the battery cables also could cause that as bombon stated... good luck man.
","text":"Wiring harness ? Is that those clip things that are on all the electric ","replyToPid":59477}
 楼主| 发表于 2019-6-8 14:59:34 来自手机 | 显示全部楼层
712925 发表于 2019-06-08 06:58:24 Wiring harness ? Is that those clip things that are on all the electric
","text":"And also the computer is basically in the dash follow those wires where the fire wall is?","replyToPid":59478}
发表于 2019-6-8 15:11:52 来自手机 | 显示全部楼层
{"replyTo":"","text":"yes that is correct. but it will be the main plug in.. should be a thick set of wires all wrapped into one and the largest plug in on the computer.... the only reason I recomend that is because mind did exactly what your talking about and that was the problem","replyToPid":0}
发表于 2019-6-8 15:12:26 来自手机 | 显示全部楼层
{"replyTo":"","text":"should be right on the fire wall usually on the driver side","replyToPid":0}
发表于 2019-6-8 16:28:02 来自手机 | 显示全部楼层
{"replyTo":"","text":"Alternator going bad or Power Distribution Box going bad.","replyToPid":0}
发表于 2019-6-8 17:58:34 来自手机 | 显示全部楼层
{"replyTo":"","text":"Definitely wiring.Has a similar issue in a hydrovac and it was a wiring issue.","replyToPid":0}
GMT+8, 2026-4-17 14:25 , Processed in 0.099003 second(s), 25 queries .
