查看: 164|回复: 4
Bridge Heights
 楼主| 发表于 2021-9-2 07:37:53 来自手机 | 显示全部楼层 |阅读模式
{"text":"Does this app account for your height you list in your load? Is there anywhere to look up bridge clearances? Thanks in advance","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2021-9-2 07:56:55 来自手机 | 显示全部楼层
{"replyTo":"","text":"Don't worry about bridge height driver!! But do Tp community a favor??? Setup camera before you go under  a 9 ft bridge. 🤣🤣🤣🤣","replyToPid":0}
回复 支持 5 反对 1
发表于 2021-9-8 01:10:45 来自手机 | 显示全部楼层
{"replyTo":"","text":"ATLAS TELLS YOU EVERYTHING AND ROAD SIGNS, you know those big metal things that are bolted to the posts sticking out of the ground or the ones that are plastered all over the bridges in yellow with black letters and numbers","replyToPid":0}
发表于 2021-9-2 07:47:15 来自手机 | 显示全部楼层
{"replyTo":"","text":"Garmin has bridge heights and so does ol faithfull AKA Rand McNally","replyToPid":0}
发表于 2021-9-2 07:47:13 来自手机 | 显示全部楼层
{"replyTo":"","text":"https://www.randmcnally.com/product/rand-mcnally-motor-carriers-road-atlas","replyToPid":0}
GMT+8, 2026-4-17 16:50 , Processed in 0.094613 second(s), 24 queries .
