查看: 44|回复: 3
Voice
 楼主| 发表于 2021-8-31 08:05:56 来自手机 | 显示全部楼层 |阅读模式
{"text":"How do you turn off the voice directions so it doesn’t affect my music","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2021-8-31 08:14:12 来自手机 | 显示全部楼层
{"replyTo":"","text":"When navigating select the middle bottom portion and then other options menu will pop up and you can turn it off","replyToPid":0}
发表于 2021-8-31 08:07:38 来自手机 | 显示全部楼层
{"replyTo":"","text":"I don’t know ","replyToPid":0}
 楼主| 发表于 2021-8-31 10:08:55 来自手机 | 显示全部楼层
1244968 发表于 2021-08-31 00:14:12 When navigating select the middle bottom portion and then other options menu will pop up and you can turn it off
","text":"I’ll try that if they ever get the damned app to work again","replyToPid":442647}
GMT+8, 2026-2-8 21:48 , Processed in 0.113648 second(s), 24 queries .
