查看: 343|回复: 11
Looking for a truck to buy
 楼主| 发表于 2021-8-26 01:04:05 来自手机 | 显示全部楼层 |阅读模式
{"text":"I'm looking for a pre-emissions truck 2016 and older. Message me if anyone has wanted to sell for less than 70,000 USD.  \n\nI live around Michigan Detroit so if you're in the area that would also help a lot.","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2021-8-26 03:34:07 来自手机 | 显示全部楼层
766797 发表于 2021-08-25 17:48:51 pre emission  is 203 and older
","text":"I thought. it was 2000 or older","replyToPid":441799}
发表于 2021-8-28 05:05:34 来自手机 | 显示全部楼层
766797 发表于 2021-08-26 00:43:12 glider be any year when you use new rolling chastened (glider) and put older drive train. 1999 is for ELD exemption
","text":"ahhhh thats it..... dang things get so confusing with all the rule changes","replyToPid":441913}
发表于 2021-8-27 20:03:28 来自手机 | 显示全部楼层
612134 发表于 2021-08-25 19:34:07 I thought. it was 2000 or older
","text":"No mid year 2005 and back doesn’t have the DEF OR egr system. I’ve got a C-15  in s 04 KW ITS A NON TWIN TURBO AND NO EGR . . It gets around 6.35 mpg . It was inframed about 550k miles ago . ","replyToPid":441848}
发表于 2021-8-26 19:52:54 来自手机 | 显示全部楼层
766797 发表于 2021-08-26 11:39:31 have rebuild 3406B large injectors, large turbo,reborrerrd block,ceramic manifold  total engine cost with labor $60k last week have lv.1 the officer enjoy it call another 3 to see he just heard it and said what under the hood read the build print and dino  and falls in love‼️🇺🇸🦕😅😆😂😀
","text":"thats awesome! I ran a '94 Pete with a 3406B motor, that was a great running truck. Only issues I had was the frigid cold and fuel gelling","replyToPid":441947}
发表于 2021-8-26 20:00:20 来自手机 | 显示全部楼层
{"replyTo":"","text":"You have to get older than 2006 to get away from emissions and even some of those have them","replyToPid":0}
发表于 2021-8-26 04:08:20 来自手机 | 显示全部楼层
{"replyTo":"","text":"yes the glider requirements are a 1999 motor or older","replyToPid":0}
发表于 2021-8-26 04:10:28 来自手机 | 显示全部楼层
{"replyTo":"","text":"I drive a 2016 with an E model motor the only gauge that didn't line up was the air filter","replyToPid":0}
发表于 2021-8-26 08:43:25 来自手机 | 显示全部楼层
","text":"Ritchie auction may be ","replyToPid":441799}
发表于 2021-8-26 10:47:18 来自手机 | 显示全部楼层
发表于 2021-8-26 18:55:15 来自手机 | 显示全部楼层
766797 发表于 2021-08-26 04:15:27 was just explaining glider term now everyone rebuilding 🦕🦕🦕 like me‼️😂😀talked with Bruce in Pittsburgh Power  3 to 4 calls daily about mechanical trucks...
","text":"I have heard they are cracking down on glider builds and pre-emmision engines to the point it is almost impossible to get one built anymore?","replyToPid":441934}
GMT+8, 2026-4-17 18:14 , Processed in 0.124730 second(s), 24 queries .
