查看: 32724|回复: 61
App Feature: Pick Entrance
 楼主| 发表于 2021-8-24 18:16:27 来自手机 | 显示全部楼层 |阅读模式
{"text":"Hello Trucker Path users, \n\nyou can pick a truck entrance at your destination in trip plan starting from version 5.1.8. \n\nLet us know how you guys like this improvement!","videos":"[]","link":"{}","pics":"[{\"description\":\"Pick Entrance\",\"height\":938.0,\"name\":\"\",\"url\":\"\",\"width\":375.0}]","canComment":true,"externalShare":false}
发表于 2021-8-25 09:20:04 来自手机 | 显示全部楼层
{"replyTo":"","text":"what you really need to do is show low clearance bridges reliably","replyToPid":0}
回复 支持 11 反对 1
发表于 2021-8-25 09:15:46 来自手机 | 显示全部楼层
回复 支持 10 反对 2
发表于 2021-8-25 09:07:53 来自手机 | 显示全部楼层
{"replyTo":"","text":"yall need to update  some of the streets  trucker path say go this way and turns to be a no truck allows  on those streets","replyToPid":0}
回复 支持 11 反对 0
发表于 2021-8-25 09:29:39 来自手机 | 显示全部楼层
{"replyTo":"","text":"your app needs to recognize that a truck and 53' trailer cannot just make a U-turn any given chance.","replyToPid":0}
回复 支持 9 反对 1
发表于 2021-8-25 09:18:44 来自手机 | 显示全部楼层
637632 发表于 2021-08-25 01:15:46 what you really need to do is show low clearance bridges reliably
","text":"and truck routes accurately","replyToPid":441648}
回复 支持 9 反对 0
发表于 2021-8-25 09:28:48 来自手机 | 显示全部楼层
{"replyTo":"","text":"\"No trucks\" streets need to be updated.  Shitton of them in WI and IL.","replyToPid":0}
回复 支持 8 反对 0
发表于 2021-8-25 09:42:43 来自手机 | 显示全部楼层
{"replyTo":"","text":"app has started to freeze and not reload route when minimized and reopened. you have to just quit the route and reselect destination in the history to have the route restored. also once route has been active when trying to select a truck stop etc. along route you have to zoom in and out on the map a certain way to keep those locations showing just to be able to select one. things with this app starting to not be worth it for the money hammer is free and some how better they've built a truck route off of Google maps that was a smart move to partner with them and be able to build truck routes.","replyToPid":0}
回复 支持 7 反对 0
发表于 2021-8-25 09:35:03 来自手机 | 显示全部楼层
{"replyTo":"","text":"Who designed the Micro Font on the Destination Page? Please enlarge the Font!","replyToPid":0}
回复 支持 6 反对 0
发表于 2021-8-25 09:09:21 来自手机 | 显示全部楼层
{"replyTo":"","text":"I like this because it helps other drivers n us makes it that much easier so we don't get into a tough pickle we can't get out of if it's bad but if it's a not bad but can't see where a semi can enter it helps everything that can make it better makes it better for us","replyToPid":0}
回复 支持 5 反对 1
发表于 2021-8-25 09:36:33 来自手机 | 显示全部楼层
{"replyTo":"","text":"Am I the only 1 that thinks the Destination Font is too small?","replyToPid":0}
发表于 2021-8-25 09:05:09 来自手机 | 显示全部楼层
{"replyTo":"","text":"thank you for truly striving to be an efficient good app.","replyToPid":0}
回复 支持 4 反对 1
发表于 2021-8-25 09:05:18 来自手机 | 显示全部楼层
{"replyTo":"","text":"cool","replyToPid":0}
发表于 2021-8-25 09:05:50 来自手机 | 显示全部楼层
{"replyTo":"","text":"good","replyToPid":0}
发表于 2021-8-25 09:06:43 来自手机 | 显示全部楼层
{"replyTo":"","text":"good idea thanks","replyToPid":0}
发表于 2021-8-25 09:07:01 来自手机 | 显示全部楼层
{"replyTo":"","text":"man that's awesome.  makes our job that much easier","replyToPid":0}
发表于 2021-8-25 09:07:25 来自手机 | 显示全部楼层
{"replyTo":"","text":"tha ks","replyToPid":0}
发表于 2021-8-25 09:10:40 来自手机 | 显示全部楼层
{"replyTo":"","text":"👍","replyToPid":0}
GMT+8, 2026-2-8 22:22 , Processed in 0.106325 second(s), 24 queries .
