查看: 282|回复: 17
Anyone in Weatherford Texas ?
 楼主| 发表于 2021-8-23 05:33:45 来自手机 | 显示全部楼层 |阅读模式
{"text":"Lady Viking needing assistance to bleed air out of cooling system of a 2007 Chrysler Pacifica \nThanks to anyone willing to put a call out for me . ","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2021-8-23 09:11:50 来自手机 | 显示全部楼层
{"replyTo":"","text":"if your vehicle is overheating but the coolant is topped off, the problem is either your water pump or thermostat is stuck open, or you have a blockage.","replyToPid":0}
回复 支持 1 反对 11
发表于 2021-8-23 06:51:06 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"you should not have to bleed air out of the cooling system, just fill it up to the top and run the engine and eventually the bubbles will reach the top, then top it off again."}
回复 支持 0 反对 11
发表于 2021-8-23 09:10:40 来自手机 | 显示全部楼层
{"replyTo":"","text":"if your vehicle is overheating but the coolant is topped off, the problem is either your water pump or thermostat is stuck open.","replyToPid":0}
回复 支持 1 反对 10
发表于 2021-8-23 09:48:30 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"if you run the engine and let it get to running temperature, feel the radiator, feel the upper hose, then feel the lower radiator hose. If all of it is hot, you probably do not have a blockage."}
回复 支持 1 反对 9
发表于 2021-8-23 09:56:15 来自手机 | 显示全部楼层
{"replyTo":"","text":"if you run the engine and let it get to running temperature, feel the radiator, feel the upper hose, then feel the lower radiator hose. If all of it is hot, you probably do not have a blockage.\n\nyour best option would probably be to tow it to a shop and get it fixed by a mechanic.","replyToPid":0}
回复 支持 1 反对 9
发表于 2021-8-23 10:13:24 来自手机 | 显示全部楼层
1310234 发表于 2021-08-23 01:56:15 if you run the engine and let it get to running temperature, feel the radiator, feel the upper hose, then feel the lower radiator hose. If all of it is hot, you probably do not have a blockage.\n\nyour best option would probably be to tow it to a shop and get it fixed by a mechanic.
","text":"I think I'm a mechanic but in reality I'm a lot 🐊","replyToPid":441298}
回复 支持 3 反对 2
发表于 2021-8-23 10:22:30 来自手机 | 显示全部楼层
","text":"Tp troll now is a mechanic!🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣","replyToPid":441298}
发表于 2021-8-23 06:54:03 来自手机 | 显示全部楼层
1310234 发表于 2021-08-22 22:51:06 you should not have to bleed air out of the cooling system, just fill it up to the top and run the engine and eventually the bubbles will reach the top, then top it off again.
","text":"Nobody cares what you think FORHISGLORY","replyToPid":441256}
发表于 2021-8-23 13:22:37 来自手机 | 显示全部楼层
","text":"great idea except top hose can get hot and still have no water flow if the water pump is shot. Squeeze the top hose with gloves or something  and you can feel the water bubble past if your pump is good.","replyToPid":441298}
发表于 2021-8-23 07:13:39 来自手机 | 显示全部楼层
{"replyTo":"","text":"Bleeder screw on top of the thermostat housing, or jack the front end up and remove the radiator cap.","replyToPid":0}
 楼主| 发表于 2021-8-23 07:07:18 来自手机 | 显示全部楼层
","text":"I tried that seemed fine 20 min later  right up to top red on temp gauge tried to google a fix and it comes up with bleed screw but I’m worried to try to fix it without someone who knows it better thank you for your reply ","replyToPid":441256}
发表于 2021-8-23 08:19:49 来自手机 | 显示全部楼层
{"replyTo":"","text":"Yes you can position the front of the car higher than the rear and you should be able to burp the air out","replyToPid":0}
 楼主| 发表于 2021-8-23 08:42:17 来自手机 | 显示全部楼层
936953 发表于 2021-08-22 23:13:39 Bleeder screw on top of the thermostat housing, or jack the front end up and remove the radiator cap.
","text":"Thank you ","replyToPid":441269}
 楼主| 发表于 2021-8-23 08:42:25 来自手机 | 显示全部楼层
1288269 发表于 2021-08-23 00:19:49 Yes you can position the front of the car higher than the rear and you should be able to burp the air out
","text":"Thank you ","replyToPid":441278}
GMT+8, 2026-3-22 15:34 , Processed in 0.096501 second(s), 24 queries .
