查看: 323|回复: 12
Winter
 楼主| 发表于 2021-8-23 02:48:01 来自手机 | 显示全部楼层 |阅读模式
{"text":"Hey, all you old timers, tell a newbie please. On ice and snow I already plan on going slower, but engine retarder or not? What’s the best way to slow down and to stop?","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2021-8-23 04:52:14 来自手机 | 显示全部楼层
{"replyTo":"","text":"Drive for the conditions and you’ll be able to stop accordingly.  Make sure to look at the tires of trucks as they roll by to see if you’re on ice or not if the roads look clear.  Don’t drive out of your comfort zone. 25*-32* is more slick than colder, sub freezing temperatures","replyToPid":0}
发表于 2021-8-23 05:11:47 来自手机 | 显示全部楼层
{"replyTo":"","text":"depending on the situation for you...I have used retarded but am very careful when and how...","replyToPid":0}
发表于 2021-8-23 10:16:52 来自手机 | 显示全部楼层
{"replyTo":"","text":"hello,do you wanna have some fun?I'm currently available Snapchat::rjesmine20 or (408) 684-7939","replyToPid":0}
回复 支持 0 反对 3
发表于 2021-8-23 17:46:14 来自手机 | 显示全部楼层
{"replyTo":"","text":"I prefer ‘no jake’ and ‘no cruise’ on heavy rain, fog, ice, snow, etc. and to keep it slower (of course) but utilize downshifting to remain in control at all times. Also good for ramps. Why? Downshifting requires more planning in reducing speed so your awareness is more keen as a driver. Also, when taking downgrades get into being in a proper low gear at the top of a hill whereby it is not necessary to tap the brakes at all but utilizing only the 2/4/6 cylinder jake button to regulate your speed and rpm’s within a 5 mph window. Think of your jake as a secondary back up option or an assist to your professional driving skills that you develop. Never really a good idea to slow from highway speeds to a complete stop with service brakes because of wear on brakes, and the need to have ‘fresh’ braking power in emergency while already slowing. Fir example taking a ramp, you are already braking, but the a car suddenly slows or stops, you need full air pressure and cool brakes for maximum response, and utilizing your gear downshifting method as primary way to slow down greatly helps you stay safe and alert as you preplan your vehicle operating.","replyToPid":0}
发表于 2021-8-23 10:35:38 来自手机 | 显示全部楼层
1310867 发表于 2021-08-23 02:16:52 hello,do you wanna have some fun?I'm currently available Snapchat::rjesmine20 or (408) 684-7939
","text":"Troll ","replyToPid":441312}
发表于 2021-8-23 09:39:52 来自手机 | 显示全部楼层
{"replyTo":"","text":"Depends on the conditions I did always use the engine brake when I’m driving slowly, but be careful when you are come to the curves, if it’s blizzard don’t drive just fine safe haven! ","replyToPid":0}
发表于 2021-8-23 18:18:45 来自手机 | 显示全部楼层
{"replyTo":"","text":"Did I say somewhere that ice melts to the pavement instantly?  For clarification. If it is cold out, let’s say 25*F and the roads look clear, look at the tires of a truck passing by and you’ll see if there is in fact ice in the road by seeing their tires look wet.  Happens all the time in Wyoming.  25-32 is the most dangerous temp to drive in due to the water freezing/not freezing of it has been wet out.  The colder the temps, the more traction you have!  Where am I losing you?","replyToPid":0}
发表于 2021-8-24 07:02:21 来自手机 | 显示全部楼层
{"replyTo":"","text":"why go slower. Hammer down","replyToPid":0}
禁止发言
发表于 2021-8-23 07:04:19 来自手机 | 显示全部楼层
发表于 2021-8-23 15:20:08 来自手机 | 显示全部楼层
972824 发表于 2021-08-22 20:52:14 Drive for the conditions and you’ll be able to stop accordingly.  Make sure to look at the tires of trucks as they roll by to see if you’re on ice or not if the roads look clear.  Don’t drive out of your comfort zone. 25*-32* is more slick than colder, sub freezing temperatures
","text":"Ice doesn’t melt to the pavement instantly. It doesn’t matter if there is water coming of the tires. That’s one of the dumbest things truckers say","replyToPid":441242}
GMT+8, 2026-4-16 06:17 , Processed in 0.193252 second(s), 24 queries .
