查看: 108|回复: 2
Short winch bar
 楼主| 发表于 2021-8-22 20:03:28 来自手机 | 显示全部楼层 |阅读模式
{"text":"When I first started driving back in 2017 I remember my trainer having a short winch bar for using on step-decks and in docks without much room. Lost my trainers number a long time ago and was wondering if anyone knew where I could buy one online so when I pull a step especially the step-decks with lo-pro tires I can get more out of the winch bar than just a couple of clicks. ","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2021-8-22 20:46:47 来自手机 | 显示全部楼层
{"replyTo":"","text":"here's a simple solution to your problem take a long one cut it with a torch where you wanted your got your short one","replyToPid":0}
发表于 2021-8-22 21:48:17 来自手机 | 显示全部楼层
815642 发表于 2021-08-22 12:46:47 here's a simple solution to your problem take a long one cut it with a torch where you wanted your got your short one
","text":"That's what I did, I cut it with an angle grinder and rounded off the sharp edges","replyToPid":441133}
GMT+8, 2026-2-4 13:55 , Processed in 0.071518 second(s), 24 queries .
