查看: 145|回复: 4
Spring suspension vs air ride trailers
 楼主| 发表于 2021-8-18 01:51:29 来自手机 | 显示全部楼层 |阅读模式
{"text":"Hi y’all! We have a couple of older wabash dry vans we use to haul hay. Both are air ride. I am looking at an additional van and see some with spring suspension... would you avoid spring suspension? Our loaded combined weight is usually around 65,000","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2021-8-18 02:14:23 来自手机 | 显示全部楼层
{"replyTo":"","text":"your cargo Is Not Fragile so the Spring Ride is a good option that reduces cost and maintenance with an airbag system the only problem will be you will feel every bump in the road when you are empty you might notice some higher tire wear","replyToPid":0}
发表于 2021-8-18 06:00:30 来自手机 | 显示全部楼层
{"replyTo":"","text":"is there a reason specific you're using vans to move hay bales?","replyToPid":0}
发表于 2021-8-18 06:02:09 来自手机 | 显示全部楼层
{"replyTo":"","text":"if you make a standard 34-inch Bale you can fit 6 a layer at least that's where I like to call it but inside of a dry van you can't go 6 wide","replyToPid":0}
发表于 2021-8-19 03:55:31 来自手机 | 显示全部楼层
{"replyTo":"","text":"They ride and pull like crap air is the only way to go ","replyToPid":0}
GMT+8, 2026-4-16 06:17 , Processed in 0.097641 second(s), 24 queries .
