查看: 211|回复: 5
Leaking coolant
 楼主| 发表于 2021-8-17 15:38:51 来自手机 | 显示全部楼层 |阅读模式
{"text":"Good morning truckers I’m losing coolant I look underneath and see that black lines by the side of the engine have coolant over them I think that’s the problem but not sure. Help. Thank You ","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2021-9-7 20:34:47 来自手机 | 显示全部楼层
{"replyTo":"","text":"Yo","replyToPid":0}
发表于 2021-8-17 19:32:31 来自手机 | 显示全部楼层
{"replyTo":"","text":"Check your water pump ","replyToPid":0}
发表于 2021-8-17 21:25:01 来自手机 | 显示全部楼层
{"replyTo":"","text":"if it's a 14 L Detroit the two lines usually get rusty get pin holes in them I've had to change mine","replyToPid":0}
发表于 2021-8-18 01:48:09 来自手机 | 显示全部楼层
{"replyTo":"","text":"is it a metal line or rubber? check the clamps my just need to be tightened up a bit. or replaced","replyToPid":0}
发表于 2021-8-18 01:49:40 来自手机 | 显示全部楼层
815642 发表于 2021-08-17 13:25:01 if it's a 14 L Detroit the two lines usually get rusty get pin holes in them I've had to change mine
","text":"paccar has a manifold with lines coming off it. had to replace mine last spring had a pin hole and broken bracket","replyToPid":440518}
GMT+8, 2026-4-17 18:39 , Processed in 0.074904 second(s), 24 queries .
