查看: 183|回复: 11
Important question
 楼主| 发表于 2021-8-14 09:48:28 来自手机 | 显示全部楼层 |阅读模式
{"text":"Is it bad to gross 75000lbs on a tandem axle straight truck?","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
禁止发言
发表于 2021-8-14 09:54:43 来自手机 | 显示全部楼层
禁止发言
发表于 2021-8-14 09:54:20 来自手机 | 显示全部楼层
 楼主| 发表于 2021-8-14 10:43:29 来自手机 | 显示全部楼层
{"replyTo":"","text":"I’m probably only 30 k heavy on the drives , but you don’t need to worry about that ","replyToPid":0}
发表于 2021-8-14 10:55:20 来自手机 | 显示全部楼层
{"replyTo":"","text":"Nice, easy lane changes...","replyToPid":0}
发表于 2021-8-14 10:19:15 来自手机 | 显示全部楼层
{"replyTo":"","text":"😉😂 pray the frame holds","replyToPid":0}
 楼主| 发表于 2021-8-14 19:10:51 来自手机 | 显示全部楼层
1274397 发表于 2021-08-14 01:50:47 it's worse to waste a beer
","text":"Alcohol abuse is bad","replyToPid":439975}
发表于 2021-8-14 11:34:49 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"The answers you seek are listed right on the door jamb of your truck"}
发表于 2021-8-14 14:59:16 来自手机 | 显示全部楼层
","text":"Yes that true ","replyToPid":439975}
 楼主| 发表于 2021-8-14 19:09:51 来自手机 | 显示全部楼层
936953 发表于 2021-08-14 03:34:49 The answers you seek are listed right on the door jamb of your truck
","text":"Those are just a suggestion ","replyToPid":439993}
 楼主| 发表于 2021-8-14 19:10:14 来自手机 | 显示全部楼层
942116 发表于 2021-08-14 02:19:15 😉😂 pray the frame holds
","text":"Double framed not worried at all","replyToPid":439990}
GMT+8, 2026-2-9 06:23 , Processed in 0.075734 second(s), 24 queries .
