查看: 166|回复: 9
Freight liner or international
 楼主| 发表于 2021-8-13 00:12:17 来自手机 | 显示全部楼层 |阅读模式
{"text":"Hey I have a 2020 freightliner  and I am being given an option to take 2021 international. I wanna know which one is better and more stable on road. ","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
1万
发表于 2021-8-13 03:49:32 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"probably depends on what model International truck you are talking about, there are at least 5 different models and many different specs for each model... same with the freightliner... need more information to give an intelligent answer...\n 🙂 🇺🇸 👍"}
发表于 2021-8-13 01:17:00 来自手机 | 显示全部楼层
{"replyTo":"","text":"I’d keep the freight shaker","replyToPid":0}
发表于 2021-8-13 02:12:12 来自手机 | 显示全部楼层
{"replyTo":"","text":"More stable?   Plan on taking any high speed turns through mountain canyons zipping in and out of the apex?  Haha.  ","replyToPid":0}
发表于 2021-8-13 06:53:47 来自手机 | 显示全部楼层
{"replyTo":"","text":"Keep what you have if breakdown always shops got parts to fix it like ta and petro u know not like Volvo painful u can’t get parts from truck stops ","replyToPid":0}
发表于 2021-8-13 09:16:49 来自手机 | 显示全部楼层
{"replyTo":"","text":"International would be my pick. Just my opinion ","replyToPid":0}
发表于 2021-8-13 19:48:17 来自手机 | 显示全部楼层
{"replyTo":"","text":"Personally I'd keep the Freightliner. What engine is in the international? What engine is in the Freightliner?","replyToPid":0}
发表于 2021-8-14 07:17:54 来自手机 | 显示全部楼层
{"replyTo":"","text":"Keep the freight shaker, I own a international. I can personally tell you, that if you have the money to throw away you will be fixing a lot of electrical bs with international. They are good tractors but lord when they hiccup you wanna run this mother off grapevine and hope it crashes and burns. ","replyToPid":0}
发表于 2021-8-14 20:04:59 来自手机 | 显示全部楼层
{"replyTo":"","text":"I've got a LT 2020 and just the def pump sensor went out  was down for a  few days to get part\nbeen a good truck. if yiur having whats seems to be as your windshield leaking its not that its to clearance lights that have a cheap foam gasket behind them. either run a bead of clear silicone around them or take them out and do the same on the gasket\nproblem solved","replyToPid":0}
发表于 2021-8-15 00:17:23 来自手机 | 显示全部楼层
{"replyTo":"","text":"Go with the Freightliner!!! I drive a  International and it’s a piece of CRAP!","replyToPid":0}
GMT+8, 2026-2-9 06:24 , Processed in 0.086277 second(s), 24 queries .
