查看: 114|回复: 8
Trip pak
 楼主| 发表于 2021-8-11 23:02:22 来自手机 | 显示全部楼层 |阅读模式
{"text":"Has anyone ever successfully sent a UPS trip pak? I’ve sent two but apparently they got lost. The info was filled out correctly but is there any other steps needed besides simply buting it, following the steps and putting it in the box?","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2021-8-12 07:50:38 来自手机 | 显示全部楼层
{"replyTo":"","text":"my trick was simple. I put the office address as both sender and recipient.  so no matter what it went to the office.  hope that helps","replyToPid":0}
发表于 2021-8-15 01:53:00 来自手机 | 显示全部楼层
651747 发表于 2021-08-11 23:50:38 my trick was simple. I put the office address as both sender and recipient.  so no matter what it went to the office.  hope that helps
","text":"That's what I always did as well.","replyToPid":439699}
发表于 2021-8-11 23:14:49 来自手机 | 显示全部楼层
{"replyTo":"","text":"I send them out twice a month. Never had an issue. ","replyToPid":0}
发表于 2021-8-11 23:42:19 来自手机 | 显示全部楼层
{"replyTo":"","text":"TripPak, that’s a blast from the past. ","replyToPid":0}
 楼主| 发表于 2021-8-12 02:52:18 来自手机 | 显示全部楼层
1174197 发表于 2021-08-11 15:14:49 I send them out twice a month. Never had an issue.
","text":"Do you use the reference number line? I don’t. Apparently when it’s sent out my company can’t track it and it doesn’t make it to the address they tell me to send it to even though I take off the second sheet as it says to do. Do you think that has anything to do with it?","replyToPid":439667}
 楼主| 发表于 2021-8-12 02:54:21 来自手机 | 显示全部楼层
936953 发表于 2021-08-11 15:42:19 TripPak, that’s a blast from the past.
","text":"Yeah this new company I’m with has me using them. I’ve always used transflo instead","replyToPid":439672}
发表于 2021-8-12 09:59:46 来自手机 | 显示全部楼层
{"replyTo":"","text":"Bro i left my trippack at the Petro in Ontario CA monday , as of today its still not picked up , i called customer service nothing … Wtf is going on there , been looking for somebody who is parked there now to help me to take out enevelope from the box and send me a pictures od bols so i can get my paycheck this week ","replyToPid":0}
 楼主| 发表于 2021-8-16 23:26:14 来自手机 | 显示全部楼层
","text":"I will try that. Thank you","replyToPid":439699}
GMT+8, 2026-2-4 23:45 , Processed in 0.105776 second(s), 24 queries .
