查看: 244|回复: 11
Tire Shop
 楼主| 发表于 2021-8-10 06:46:39 来自手机 | 显示全部楼层 |阅读模式
{"text":"Just curious…\nHow often do you guys go through tires on trailers vs tractors? \nWhats the dumbest thing you did or had happen to a tire?","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
禁止发言
发表于 2021-8-10 07:33:08 来自手机 | 显示全部楼层
发表于 2021-8-10 21:57:46 来自手机 | 显示全部楼层
{"replyTo":"","text":"That depends on the type of operation. A heavy flat or rng I generally get around a year to 18 mo between 150 and 200 k   Drives 350k to 425k   On a tandem trailer 425 k  ","replyToPid":0}
1万
发表于 2021-8-10 13:06:11 来自手机 | 显示全部楼层
147103 发表于 2021-08-10 00:15:06 Hey it happens.  no need to fret over it. We all make mistakes.
","text":"yes, we all make mistakes, just be sure to learn not to do it again...  👍 🇺🇸 🙂","replyToPid":439468}
发表于 2021-8-14 07:33:23 来自手机 | 显示全部楼层
{"replyTo":"","text":"At&t with signal hiboost vehicle signal booster... you pay what you get for... 500+ but you won't regret it","replyToPid":0}
发表于 2021-8-14 07:24:17 来自手机 | 显示全部楼层
{"replyTo":"","text":"Been driving 4 years, I’ve learned this don’t waste money on used or retreds. Don’t hit your tires on curbs. I check my tires every morning night and when I take my break. I put 100 in trailer and 110 on tractor. I don’t get nails like I use to. I run Bridgestones and keep my axles alighted. Also keep my tractor greased when it needs it. ","replyToPid":0}
禁止发言
发表于 2021-8-11 03:47:52 来自手机 | 显示全部楼层
 楼主| 发表于 2021-8-11 03:27:33 来自手机 | 显示全部楼层
147103 发表于 2021-08-10 12:57:18 What kind of trailer do you pull?
","text":"Just a van trailer. Had to replace the wheel. The tire itself was fine.","replyToPid":439520}
 楼主| 发表于 2021-8-10 12:47:13 来自手机 | 显示全部楼层
","text":"Im trying not to.","replyToPid":439468}
禁止发言
发表于 2021-8-10 08:15:06 来自手机 | 显示全部楼层
 楼主| 发表于 2021-8-10 08:08:53 来自手机 | 显示全部楼层
147103 发表于 2021-08-09 23:33:08 Sounds like your shop not monitor tire pressure or run recaps
","text":"My shop does great. I just did a rookie mistake and i’m waiting to get a rim bent back into place. I’m beyond pissed at myself over it.","replyToPid":439460}
禁止发言
发表于 2021-8-10 20:57:18 来自手机 | 显示全部楼层
GMT+8, 2026-2-9 07:47 , Processed in 0.076012 second(s), 24 queries .
