查看: 191|回复: 5
fyi. Garden inn trckstop in Cabool Mo. needs to be avoided and boycotted due to sanitary reasons. all employees wear mas
 楼主| 发表于 2021-8-8 04:48:25 来自手机 | 显示全部楼层 |阅读模式
 楼主| 发表于 2021-8-8 12:14:43 来自手机 | 显示全部楼层
1027883 发表于 2021-08-08 03:45:58 The holes in a mask are 50,000x as big as a China-Virus particle. Masks do absolutely nothing, you low-info sheep. The only reason they are recommended is so we have a visual reminder that a \"pandemic\" is happening because without them people would quickly forget about this virus with a higher survival rate than the Flu. Get a grip, pu**y.
","text":"covid is a hoax. get your facts straight before you call anyone sheep. you gossiping POS","replyToPid":439235}
 楼主| 发表于 2021-8-8 11:45:13 来自手机 | 显示全部楼层
{"replyTo":"","text":"not all employees.  there were some that tried to do their job, but were stopped by management. yes I'll complain because the place is nasty as well as a lot of workers. but when managers won't fix the problem and only hire more of the same, they need new owners","replyToPid":0}
发表于 2021-8-8 11:45:58 来自手机 | 显示全部楼层
438324 发表于 2021-08-07 22:15:57 wow you complain when a place is nasty but not when others turn a place nasty because they are gross and pigs \nlike looking in the mirror.\nim not saying your one of the ones but this is what I have trying to say
","text":"The holes in a mask are 50,000x as big as a China-Virus particle. Masks do absolutely nothing, you low-info sheep. The only reason they are recommended is so we have a visual reminder that a \"pandemic\" is happening because without them people would quickly forget about this virus with a higher survival rate than the Flu. Get a grip, pu**y.","replyToPid":439221}
发表于 2021-11-8 05:58:08 来自手机 | 显示全部楼层
{"replyTo":"","text":"funny, the anti maskers are the only ones dying of Covid. the 'dId mY oWn rEsEArCh' l0sers","replyToPid":0}
发表于 2021-8-8 06:15:57 来自手机 | 显示全部楼层
{"replyTo":"","text":"wow you complain when a place is nasty but not when others turn a place nasty because they are gross and pigs \nlike looking in the mirror.\nim not saying your one of the ones but this is what I have trying to say","replyToPid":0}
GMT+8, 2026-2-4 15:03 , Processed in 0.068266 second(s), 25 queries .
