查看: 299|回复: 18
Unable to use restroom at reveiver
 楼主| 发表于 2021-8-6 00:34:21 来自手机 | 显示全部楼层 |阅读模式
{"text":"Aristech in Florence, KY.  Brought in a tarped load. Been here for two hours after untarping and sweating like crazy.  Asked to use the restroom so I can take a number two and they state both public restrooms!?!?!   Where’s the humanity?  Makes me want to crap in a bag and throw it at their wall hoping it splatters all over like art","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2021-8-6 05:09:36 来自手机 | 显示全部楼层
972824 发表于 2021-08-05 21:06:37 The problem is that we are losing our sense of decency in helping drivers.  Do the employees working their warehouse have to go somewhere else?  No!
","text":"The problem is that many truckers behave like animals. They vandalize their restrooms and trash their properties. We won’t be treated with respect until we as truckers learn to behave like decent human beings. ","replyToPid":438943}
回复 支持 7 反对 3
发表于 2021-8-6 05:12:11 来自手机 | 显示全部楼层
279311 发表于 2021-08-05 19:42:56 Carry a 5 gal bucket in your truck with a few 13 gal kitchen trash bags. If you do OTR, you’ll eventually bump into scenarios where there are no restrooms at all. This happens to me like 1-2 times per year. You gotta be prepared.
","text":"Tell everyone all you carry in truck.........like Lube,condoms and buttt plug............😁🌈","replyToPid":438922}
回复 支持 5 反对 1
 楼主| 发表于 2021-8-6 05:12:06 来自手机 | 显示全部楼层
279311 发表于 2021-08-05 21:09:36 The problem is that many truckers behave like animals. They vandalize their restrooms and trash their properties. We won’t be treated with respect until we as truckers learn to behave like decent human beings.
","text":"I was going to add that into my last statement and you are 100% correct.  Pee bottles are the worst.  I use one everyday. But I walk to the grass to dump it then I throw away the jug.  Not hard to have some sort of decency.  ","replyToPid":438944}
发表于 2021-8-6 00:49:16 来自手机 | 显示全部楼层
{"replyTo":"","text":"I’m at a shipper and they have all restrooms blocked off to the public and drivers. They told me I can’t leave so I walked across the street and took care of my business at the gas station. They told me I can’t enter because I left so I jumped the brick wall got back in my tractor. I told them don’t pïss down my back and tell me it’s raining. That shut them up. ","replyToPid":0}
发表于 2021-8-6 03:42:56 来自手机 | 显示全部楼层
{"replyTo":"","text":"Carry a 5 gal bucket in your truck with a few 13 gal kitchen trash bags. If you do OTR, you’ll eventually bump into scenarios where there are no restrooms at all. This happens to me like 1-2 times per year. You gotta be prepared. ","replyToPid":0}
回复 支持 1 反对 3
发表于 2021-8-6 00:53:04 来自手机 | 显示全部楼层
{"replyTo":"","text":"I would shi. T in a bag and put it in their mailbox!","replyToPid":0}
发表于 2021-8-6 05:16:33 来自手机 | 显示全部楼层
972824 发表于 2021-08-05 21:12:06 I was going to add that into my last statement and you are 100% correct.  Pee bottles are the worst.  I use one everyday. But I walk to the grass to dump it then I throw away the jug.  Not hard to have some sort of decency.
","text":"👍","replyToPid":438946}
回复 支持 0 反对 3
发表于 2021-8-6 07:55:40 来自手机 | 显示全部楼层
","text":"MR Redddit is giving more of his knowledge.....🤣🤣🤣🤣🤣🤣 on subject your probably good at TOILET!  🤣🤣🤣","replyToPid":438944}
 楼主| 发表于 2021-8-6 05:06:37 来自手机 | 显示全部楼层
{"replyTo":"","text":"The problem is that we are losing our sense of decency in helping drivers.  Do the employees working their warehouse have to go somewhere else?  No!  ","replyToPid":0}
发表于 2021-8-6 07:13:05 来自手机 | 显示全部楼层
","text":"You have got it figured out my friend!!","replyToPid":438944}
发表于 2021-8-6 01:10:53 来自手机 | 显示全部楼层
1258332 发表于 2021-08-05 16:53:04 I would shi. T in a bag and put it in their mailbox!
","text":"Put a little yeast in it for a bigger surprise. ","replyToPid":438882}
发表于 2021-8-6 03:33:25 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"just mean spirited and now covid is just an excuse to trwat others poorly"}
 楼主| 发表于 2021-8-6 05:04:28 来自手机 | 显示全部楼层
","text":"I always carry gallons of water.  I was shutdown on the highway in Wyoming over the winter with massive blowing snow from all directions.  Knew that it was going to be a bit more wet so I had to cut off the top of the gallon of water and went in it.  ","replyToPid":438922}
GMT+8, 2026-2-9 06:24 , Processed in 0.064699 second(s), 24 queries .
