查看: 226|回复: 7
low bridge alert
 楼主| 发表于 2021-7-31 20:32:35 来自手机 | 显示全部楼层 |阅读模式
{"text":"Hey all, just got trucker path and I'm trying to figure out if there is a low bridge alert or some kind of low clearance alert. Anyone know? Thanks and be safe out there!","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2021-7-31 23:41:49 来自手机 | 显示全部楼层
{"replyTo":"","text":"If your relying on a app to help you drive and look for bridges going need to quit your job. Stop and read what you wrote. Are seriously asking this? Do you have Down syndrome? Do you have bad vision? Did you work for CRENGLAND? ","replyToPid":0}
回复 支持 3 反对 3
发表于 2021-8-1 03:47:22 来自手机 | 显示全部楼层
{"replyTo":"","text":"check the Atlaas  it will tell you","replyToPid":0}
发表于 2021-8-1 03:11:34 来自手机 | 显示全部楼层
1221746 发表于 2021-07-31 16:24:18 Enter your vehicles settings. Height, width, weight. You can set up settings for multiple vehicles. Always tempered with common sense, eyes, ears, logic...
","text":"Check your settings for warnings and set your truck trailer profile and also check in a Rand McNally for height restrictions, the other person doesn’t know what you are hauling to try and trash talk for asking a question. Just wait until he gets into trouble and then he’ll remember his comments.","replyToPid":438333}
发表于 2021-8-1 00:24:18 来自手机 | 显示全部楼层
{"replyTo":"","text":"Enter your vehicles settings. Height, width, weight. You can set up settings for multiple vehicles. Always tempered with common sense, eyes, ears, logic...","replyToPid":0}
发表于 2021-8-1 05:10:29 来自手机 | 显示全部楼层
{"replyTo":"","text":"It's a brilliant idea. A transmitter on an overpass, you could attach it with duct tape...sends a warning signal to an app, if the trucks app settings are out of parameter. In this day and age? Stay safe, keep trucking, Driver.","replyToPid":0}
发表于 2021-8-1 21:20:47 来自手机 | 显示全部楼层
{"replyTo":"","text":"Don’t rely on phone apps. Use your road atlas…..","replyToPid":0}
发表于 2021-8-9 21:32:48 来自手机 | 显示全部楼层
{"replyTo":"","text":"When you here the top of the trailer crunching is the alert you will hear. Then a sudden stop following the alert.  ","replyToPid":0}
GMT+8, 2026-2-5 10:22 , Processed in 0.111397 second(s), 24 queries .
