查看: 296|回复: 8
Truck parked
 楼主| 发表于 2021-7-31 03:22:21 来自手机 | 显示全部楼层 |阅读模式
{"text":"For u experienced guys is it bad for my truck to leave it hooked to a load for a couple of days parked? Tight spacing makes it hard to unhook but i dont want to do any damage to my truck. Just looking for advice.","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2021-7-31 03:37:11 来自手机 | 显示全部楼层
{"replyTo":"","text":"No problem.  It won’t damage your truck at all.  Very common to do this","replyToPid":0}
 楼主| 发表于 2021-7-31 04:07:02 来自手机 | 显示全部楼层
1025907 发表于 2021-07-30 19:37:11 No problem.  It won’t damage your truck at all.  Very common to do this
","text":"Thanks!","replyToPid":438228}
 楼主| 发表于 2021-7-31 04:06:55 来自手机 | 显示全部楼层
147103 发表于 2021-07-30 19:33:07 just drop your landing gear. but leave truck hooked
","text":"Thanks we did that !","replyToPid":438227}
禁止发言
发表于 2021-7-31 03:33:07 来自手机 | 显示全部楼层
发表于 2021-7-31 18:36:44 来自手机 | 显示全部楼层
{"replyTo":"","text":"I leave my truck j and trailer hooked up for months at a time. I run my own trailer and have a Teflon plate fifth wheel. No mess. No fuss. Have never had an issue. I remember about 30 years ago hearing the old timers say that leaving a load on would ruin wheel bearings, since all the weight was resting on only one spot on the bearing. Either they’ve come up with better bearings (like a lot of other improvements) or else that theory was false. After all, the trailer was unhooked with a load on it also…\nJust my $.02","replyToPid":0}
发表于 2021-7-31 13:03:12 来自手机 | 显示全部楼层
{"replyTo":"","text":"Leave it hooked up and drop landing gear. Lock your truck up, your trailer, your spare, lol put a locking fuel cap if you got a reefer and your good ","replyToPid":0}
发表于 2021-8-12 10:19:27 来自手机 | 显示全部楼层
{"replyTo":"","text":"Trucks are built to hold your load no worries but depending on where you park you may need to pad lock your trailer ","replyToPid":0}
发表于 2021-8-17 20:22:22 来自手机 | 显示全部楼层
{"replyTo":"","text":"I unhook my trailer to truck wash and grease my 5th wheel. that's it really","replyToPid":0}
GMT+8, 2026-4-16 06:18 , Processed in 0.104775 second(s), 24 queries .
